Old 04-24-2012, 02:58 AM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
Default Help me choose a tire for KMC slides
I'm looking to pull the trigger on some 22" Black KMC slides and narrowed it down to a 305 45 tire. My two options are Nitto 420s and Yokohama Prada spec-x.
The specs on the Nittos
Overall Diameter- 32.6"
Overall Width- 11.85"
The specs on the Yokos
Overall Diameter- 32.9"
Overall Width- 11.5"
The Nittos have a little more thread depth but the Yokos have a Higher speed rating. KMC Slides are 9.5" wide and have an offset of +15 or +38 and I read the +38 rubs so I'll be going with a +15. With that being said I want the wheels to tuck in as much as possible so should I just go with the Yokos because they are slightly less as wide and will fill the wheel wells a tad better? I was looking at dodgert 22" kmc slides and they do stick out a bit and I believe he has nittos on his. I'm just wondering if that .3 an inch will make a difference. Also I would like to hear which tire is better for grip from you guys. Thanks in advance
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 04-24-2012, 05:12 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
The 420S is a pretty tried and true low pro tire. I really have never heard a big complaint about them. Ive never been a fan of yoko tires, I ran a set on the front of my camaro once cuz i got the cheap and they were loud and didnt grip as well as my no drag radial nitto 555s did (were talking on the front not the rear for these, I had mickey thompsons on the rear so cant comment)
As far as the .3" Nittos are known to run a little narrower than advertised, and look at a ruler, .3 is really nothing
2011 Big Horn 4x4 -SnowWhite-
Old 04-24-2012, 07:51 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
I think +38 deffinetly wont work, especially with a wider rim, stock is 9" wide with +18. I have no idea about either tires though. Just thought I would throiw that out there about the rim offset so that they dont rub and then your out of pocket
Old 04-24-2012, 08:56 PM
Rep:111
Yeah I know that....I should have my wheels and tires tomorrow, I went with the 305 45 22 nitto 420s.
Old 04-25-2012, 06:06 AM
SS4Luck's Avatar
Rep:310
good choice man! I totally forgot you asked about offset in my first reply.
How much is it all costin ya if you dont mind me asking. Im on the fence baout 22s or 24 slides lol
