Old 04-24-2012, 02:44 AM
Subydude09's Avatar
Subydude09 Subydude09 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4x4 Crew
Rep:50
Subydude09 will become famous soon enough
Default Side Puddle Lamp Replacement
Apparently my passenger side puddle lamp mounted under the side mirror has burned out/quit working.
Anyone have any idea how to access these lights for replacement?
Owners manual doesn't even mention them...
*Tow Hooks *LineX *Truxedo Bed Cover *SS Step Bars *HID's *Flowmaster 40 *35% Tint *Nightshades
Old 04-24-2012, 02:48 AM
Rep:2640
I am guessing here
Rotate your mirror glass all the way out
you should see the clip(s) that holds the mirror glass in
once removed, you should be able to figure it out
Old 07-09-2012, 10:45 AM
JLong's Avatar
JLong JLong is offline
Vehicle: 2009 Dodge Ram 1500 Laramie
Trim Level: 4x4 Crew Cab
JLong is on a distinguished road
My Driver side is a bright white color and my passenger side is a not as bright blueish. is that normal?
Old 07-09-2012, 08:18 PM
slack3r724 slack3r724 is offline
Vehicle: 2013
slack3r724 is on a distinguished road
I've got the same issue from all the searching most people say you can't service them they need replaced, you can get it done under the 3/36k warranty.
"Just want to let everyone know that the 4th gen puddle lights are not properly sealed from the factory and will become water logged and corrode. Both left and right on my truck are corroded already.
I just picked up another puddle light from a 2011 and you can visibly see the two halves are not properly sealed and it had some water in the unit.
YOU CANNOT BUY JUST THE PUDDLE LIGHTS FROM DODGE
(You must buy the entire mirror assembly)
**save yourself time and money and reseal yours with some silicone!**"
Hope this helps
Old 07-14-2012, 01:45 PM
dodge3800 dodge3800 is offline
Vehicle: 2012
Trim Level: St
Color: Deep chenrry
dodge3800 is on a distinguished road
You don't need to replace the entire mirror, the puddle lamp can be purchased for about $40 from your dealer.
Old 07-14-2012, 01:50 PM
BigTJohn's Avatar
BigTJohn BigTJohn is offline
Vehicle: 2012 Ram 2500
BigTJohn is on a distinguished road
Will a thinner sealer work, like a lacquer seal or enamel seal? Seems silicone will be a bit much but I guess if one is careful...
"Life is not too short, just that you are dead for so long..."
Old 07-14-2012, 02:16 PM
Rep:2640
On my '09, i have not seen any water in my puddle lamps
it now has 66,000 miles on it
where i live it doesn't rain a lot
but i wash it often at the car wash
Old 07-14-2012, 03:20 PM
BigTJohn's Avatar
Since I do not know, can puddle lights and in mirror signals be "flashed" by the dealer to function if they are an after install but OEM? I am thinking of replacing my reg mirrors with newer flipup tow mirrors.
Old 07-15-2012, 01:57 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
Think when mine go bad I will just smoke them extremely dark.
Old 07-18-2012, 08:32 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
i beleive someone on this site did replace one of them but he was saying that the replacement bulb are not blueish their white,.. so unless you buy the hole assembly you might end up with one side white they other blueish
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
