Old 04-25-2012, 10:17 AM
81X11 81X11 is offline
Vehicle: 1998 Dodge Ram 1500 Quad Cab
Trim Level: Laramie SLT
Color: Green and Grey
Rep:14
81X11 is on a distinguished road
Default Crappy Dash Plastic!!!!
So I went to remove my dash bezel around the gauges last night on my '98 Ram. Needed to get the number off the radio so I can look for a replacement. My upper dash is cracked, but the gauge bezel was not....well it is now...
I did not break it taking it off, was super careful. I was putting it back on and lightly pushing below the radio and suddenly a crack appeared in the upper right corner. Amazing, was not touching anywhere near there! I was not twisting the bezel or anything!
It gets better...I was just SICK that it cracked, especially since my truck has the nice wood-faced bezel and they are harder to find. I pulled the bezel back off and attempted to epoxy the crack from the backside and while pressing the crack together while the epoxy bonded, another crack appeared below my hand! I WAS NOT pressing hard! What are these, made of thin glass???
I gotta say I took the face bezels on and off of my 90's era Suburbans numerous times, have owned three Burbs, and NEVER had something like this happen. Was GM's plastic that much better than Chrysler's???
I got the bezel back on and the carpet cover hides most of the crack, but still, this just makes me so mad. That is the crappiest plastic I've ever dealt with.
Rant over.
-Mike
Old 04-25-2012, 11:39 AM
moparornocar72's Avatar
Rep:630
Plastic gets brittle after awhile especially with the sun on it. I would recommend getting a dash cover.
14.268 @ 95 MPH Full Trim
Old 04-25-2012, 02:46 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
They all for the most part are brittle. You can buy new ones that are tougher then stock although I hope your not attatched to the wood grain. I've never untll I saw your pics seen wood grain.
Old 04-25-2012, 03:59 PM
Rep:14
So far the crack is just on the outside edge around the wood...and I've got it covered with the carpet cover. I hope the crack doesn't spread into the wood....I like the wood, like you said, it's an uncommon option.
-Mike
Old 04-25-2012, 04:29 PM
Rep:2664
Different companies make different bezels & caps for your dash
some are the top of the dash & others are for the face of your dash
you can even order from some companies, the BURL wood finish, some you apply that part yourself
this company shows what is available, but they are the OEM parts & might crack again quickly
http://www.jimsautoparts.com/mopar_p...m_interior.htm
some companies just make an overlay that you put on with adhesive
this company carries both the cap type & replacement type, using modern day ABS plastic, not fiberglas
http://www.dashcoversplus.com/site/1427228/page/864510
other sites
http://www.google.com/#sclient=psy-a...w=1003&bih=527
Good Luck on your endeavor
Old 04-25-2012, 05:12 PM
Vehicle: N/A
Rep:1045
That's a bummer man I've owned two second gens, a 99 and a 00, and I've been ripping my dash off on my 00 the past month more than I care to admit, and no issues. Mabye its that wood grained option. Mabye try adding a layer of something on the inside to strengthen it. Cheap option .... duct tape haha
Old 04-26-2012, 05:06 PM
Rep:14
The dash cover hides it pretty well.
