Old 04-27-2012, 01:46 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
If there is no issue with the third gens you should be fine with the heads on it just scares me cuz i havent done it before... If there is an ud pulley i would have heard about it... If you find one for the eagle motor let me know first and i will tell if its legit...
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 04-27-2012, 01:56 AM
RamTex's Avatar
Color: Stone White
Rep:366
Also with the heads on it will be very difficult to get the #1 cylinder at top dead center(ATDC). You WILL have to pull a #1 spark plug and stick something down there and spin the motor over to get it ATDC it's hard enough to get it ATDC with the head off...
Old 04-27-2012, 01:59 AM
RamTex's Avatar
Color: Stone White
Rep:366
Im gonna be honest i think you should wait until you get those shorty headers and do it all at one time and pull the heads and lifters and replace the head gaskets just makes more since to do this the right way than to take short cuts to get it close... Just my 2 cents...
Old 04-27-2012, 10:42 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
if anything like the 3rd gens...
remove cai
drain fluids
unbolt tranny cooler, move it off to side (same with power steering cooler)
remove radiator fan/pulley fan
remove serpentine belt
remove reservoirs (coolant/window washing)
remove radiator shroud
remove coolant hoses/unbolt and remove radiator
at this point you can climb in and work closer to motor
remove alternator
disconnect wire connector on ac pump, unbolt and hang ac pump with bungee cords to hood
remove crank pulley (use a chrysler specific harmonic balancer puller)
remove 2 pulleys and belt tensioner
unbolt powersteering pump and move to side
remove coil packs
unbolt and remove valve covers
unbolt and remove rocker arms, then remove pushods (note where your pulling them out so you don't confuse with oil channels)
unbolt all the timing cover bolts (note: there are bolts coming up from oil pan to cover), don't unbolt water pump as it can come off with timing cover (also note as your taking off timing cover bolts as they are different lengths throughout)
wiggle and remove timing cover (it gets messy here as coolant will come rushing out)
dang..gotta get ready for work..I'll continue this later..
Old 04-27-2012, 12:05 PM
RamTex's Avatar
Color: Stone White
Rep:366
If you are dead set on getting the cam in sooner than later i can PM you my cell number and you can call me anytime for questions and i can walk you through the timing assembly.
Since you arent taking the heads off it may be easier to leave the stock pushrods inplace until you pull the stock cam, install the new cam and timing assembly.
Why? because it will make it easier not to accidentally put a pushrod in a wrong hole cuz you will oil a new pushrod and simply do one at a time a one for one swap if you will, down the line and not mess up.
Old 04-27-2012, 12:08 PM
RamTex's Avatar
Color: Stone White
Rep:366
And chefred is right once you get that rad out you can climb in and work inside the engine bay. Is your clutch fan removed yet?
Old 04-27-2012, 12:10 PM
RamTex's Avatar
Color: Stone White
Rep:366
remove cai
drain fluids
remove alternator
remove coil packs
I would also remove the wheel wells it makes it so much easier to work on the heads this way...
Old 04-27-2012, 12:11 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
How many miles if alot might want to replace the cam bearings
Old 04-27-2012, 01:25 PM
RamTex's Avatar
Color: Stone White
Rep:366
F that i leave that stuff to the machine shop... I doubt he wants to pull the motor but i do get what your sayin...
Old 04-27-2012, 05:00 PM
chefred112's Avatar
Rep:656
I've got over 215k miles and 2 cam swaps..haven't changed cam bearings yet..
