Old 05-06-2012, 03:35 PM
Mopar44064268's Avatar
Mopar44064268 Mopar44064268 is offline
Vehicle: 1996 Indy 500 SS/T Ram
Color: Blue w/rallye stripes
Rep:14
Mopar44064268 is on a distinguished road
So I finally got everything switched out. Guess those shackles are common for siezing to the brackets. I guess that really dont suprise me considering they have the metal sleeve inside them. Once I got the rear out which was no problem I was stuck on the leafsprings for a day or two, I aint gonna lie, but using basic hand tools was a adventure. All I did was used two ratchet straps, 50ft or so of rope, a tree and a good ol cut off wheel. With the springs outta the way, one strap hooked to the shackle connected to the front hanger and pulled it all the way forward, the other held it down, cut into it as far as i could then tied a rope to a tree and pulled it backwards, tied it down and finished cuttin through it. A torch would have worked so much better and faster but didnt have one or know anyone with one. On the drivers side it was a little more fun because the front bolt is just a hair to long to due to the gas tank being in the way. So either drop the tank or cut like 1/8 inch off the end of that bolt to avoid doing all the pryin and beatin that I did.
Now this is where it gets confusing to me, to a point. Keep in mind that rearend and leeafsprings that went back under my truck was outta a 98 sst that was "supposedly supercharged", now when I got the setup the shackles where a good 2-3 inches taller then my orginals, the diff had a adapter plug on it that plugged into the speed sensor, the springs seemed like they weighed a good 20lbs more then mine. I can kinda understand to a point that Dodge may have changed/upgraded wiring, the original owner may have done a suspension mod. but mine dont sit any different, but now can anyone tell me why my ABS and brake light is on. abs light comes on after bout 30 secs of drivinand stays on until I shut it off. I wrecked the back of mine, he wrecked the front of his. I have changed out both plugs, checked fuses, disconnected the battery. I can understand if the park brake needs to be adjusted and that is causing the idiots lights to be on or is it just a matter of takin it to Dodge and having the computer reset?
I know its long winded but I figured 94-01 were all the same. And if anyone has to do something like this maybe it could save them time and money by doing it themselves.
So any advice on these few problems I still have a greatful. thanks
Old 05-06-2012, 04:09 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
Sounds like you are making progress. There is something not connected (I can't think of it) on the top of the rear housing that is likely causing your ABS light issue. If I had my book I could tell you exactly, but I gave it to a friend recently.
It doesn't make sense that the shackles are taller on the donor truck. Was it off a 4x4?
Old 05-06-2012, 06:26 PM
Rep:14
Yea I made it. Using only hand tools, a lil 2 ton jack and doing it by myself. It only took a week.
And if ya talkin bout that sensor on top of the pumkin (speed sensor) it is plugged in, I have even changed the one that was in the 98 rear with the one that was in my 96 rear and the only difference I noticed was the ABS light would go off once started then come back on after bout 20 secs of drivin and the parkin brake seemed to loosen up a little more. Other then that I aint gotta clue?
Old 05-07-2012, 07:41 PM
Rep:14
Well I was lucky enough when I stopped by the local Dodge dealer today today the service mang. talked with me and I explained what all happened with my truck, the rear I replaced it with, the ABS and park brake lights being on and luckily enough he just grabbed the scan tool did it for me without any hassle. The only code that came up stored or active was this (78) Brake Foundation. He told me that it was a code he personally had never seen or heard of before.
So unless anyone on here can give me some input my interenet search begins.
Old 05-07-2012, 07:52 PM
Rep:14
Oh and MF2000 had a buddy say the same thing bout the springs being off a 4x4. They were off a 98 sst but like I said before they wieghted bout a good 20-25lbs more then mine and it would make sense seeming how the shackles appear to be lowering shackles but it did not change the stance of my truck and the 98 sst did sit bout as high a mine(being stock) from what the guy who sold me the rear setup said and pictures showed. So yea I am just glad to have it back on the road, now for these darn codes.
Old 05-07-2012, 09:22 PM
MF2000's Avatar
Color: Inferno Red
Rep:13
I'm glad it worked out for ya. Good job to you
