Old 05-11-2012, 11:05 PM
08ramtrx4 08ramtrx4 is offline
Vehicle: 2008 dodge ram 1500
Trim Level: TRX4
Color: Elec Blue
08ramtrx4 is on a distinguished road
Default Wanting to use bilstien 5100's to level truck
So i am reading i can use these to level the truck how well do they work and hows the ride. I have a trx4 so how much height will i gain?
Old 05-11-2012, 11:21 PM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Cheap Canadian Labour
Rep:1808
I have a TRX as well and have looked into leveling also. I was told that the Bilstiens are the only way to level the TRX properly as the leveling spacers won't work. You may want to call a local lift and spring shop and see what they say as well.
Old 05-11-2012, 11:52 PM
Trim Level: TRX4
Color: Elec Blue
B.w since you have a trx.What makes it a trx i know skid plates and nice red shocks and tow hooks.But what else like doseit have a better locker in the rear end??
Old 05-14-2012, 11:26 AM
Trim Level: TRX4
Color: Elec Blue
So is this a good idea?
Old 05-14-2012, 12:49 PM
Black1 Black1 is offline
Vehicle: 2012 Ram 1500
Black1 is on a distinguished road
Not really. Especially if you tow or haul anything of substance. It's form over function.
Old 05-14-2012, 02:44 PM
Trim Level: TRX4
Color: Elec Blue
Maybe a four wheeler or a boat. And I don't plan to max them out just want to take some rake out of the truck and add some hight.
Old 05-15-2012, 10:08 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Adding bilsteins to the front wont hurt yout towing performance at all lol
The truck will ride better than stock for sure as the bilsteins are a better quality shock and will do better over the bumps and everything else. Just make sure to get it re aligned after the install
2011 Big Horn 4x4 -SnowWhite-
Old 05-15-2012, 11:05 AM
Trim Level: TRX4
Color: Elec Blue
Come to find out I think its cheaper this way to level the truck then to get a spacer and new shocks.I think if I adjust them for two inches ill be fine.
Old 05-15-2012, 01:44 PM
RAMROD5's Avatar
RAMROD5 RAMROD5 is offline
Vehicle: 2006 Dodge Ram 3500 Dually
Rep:13
RAMROD5 is on a distinguished road
not totally true, for small/mild towing and hauling your right, but for the guys who really work these trucks, with 1500 lbs in the bed or towing 6k or more, the rake is there so when the truck is loaded down it still sits level and still has very positive steering and control. when the truck is level to begin with, and you load it down, it leans back, taking weight off the front of the rig and just all around making it look like a horrible/improperly set up tow vehicle, also has negative effects on steering etc.....so its a mod for some, and not others, one thing ive seen on this forum, is many people have trucks and dont seem to ever put them to work 95% of the time, i supposed that is where this mod comes in handy.
2006 Ram 3500 Dually, 5.7 hemi.
Old 05-15-2012, 02:18 PM
Trim Level: TRX4
Color: Elec Blue
That's why I wont fully adjust the shock to its max settings I want a lil rake but not alot and want to be nice to the cvs
