Torque Converter problems - Page 6 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-29-2013, 08:44 PM
obxram obxram is offline
Vehicle: 2010 ram 1500 trx4
Trim Level: trx4
Color: gray two tone
obxram is on a distinguished road
Default Army of one help
I was reading about tq problems and well I am in the same boat. They replaced my tq with the r8 part number and I returned it the same day with the rumble strip feeling in the truck.
Are you and your dealer still willing to inform my dealer of the new part numbers and updates to the star case?
Thanks in advance
Old 09-01-2013, 12:17 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
I can call my service manager on tuesday and see if he could help. Where are you located?
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 09-01-2013, 01:14 PM
gfviperman gfviperman is offline
Vehicle: 2011 RAM Crew
gfviperman is on a distinguished road
My 2011 seems to downshift to first after a complete stop.
Is this TC issue as well?
Old 09-03-2013, 07:50 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:518
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Originally Posted by huntergreen View Post
what is the difference between a tsb and a star case?
If my understanding is correct, a "STAR case" is a record (typically) of a single call / resolution at our STAR Center (dealer technical assistance hotline). So basically, it tells about a problem (and hopefully, what fixed it) for one particular vehicle at one particular dealership. STAR cases are then used as a reference (by our STAR agents), so if another dealer calls in with a similar problem on a similar vehicle, the agent can advise what might fix the issue. However, there is also a "STAR Online" system, a database where certain "popular" problems (and solutions) are described. Dealer technicians can access the STAR Online system to look for possible resolutions for issues on a particular type of vehicle (without having to call in to an agent). While these records are normally referred to as "STAR Online solutions," I suppose they might also be called "STAR cases" (since they typically originate as a single STAR case).
A TSB is a Technical Service Bulletin, which is an official bulletin addressing a known issue, which is published to all dealers. It basically advises of a particular problem, which vehicles may exhibit that problem (for example, all 2013 DS models with 5.7L engine, built before 12/15/11), how to fix it, and whether this repair will be covered under warranty.
So a STAR case and a TSB are both sources where dealers can find how to fix a particular problem on a particular type of vehicle. A TSB is more visible and "more official" (if that makes any sense) than a STAR case. A TSB requires more review and approvals than a STAR case. And a TSB (if I understand correctly) can authorize "extended warranty" repairs (i.e. repairs paid by Chrysler even after the normal warranty has expired). A STAR case does not affect or extend warranty coverage.
Old 01-23-2014, 01:42 PM
NorthernMIKE NorthernMIKE is offline
Vehicle: 2011 Dodge Ram
Trim Level: Outdoorsman
NorthernMIKE is on a distinguished road
Just to update this thread. I took my 2011 Ram into the dealer (Ontario Canada) for the TC problem in November 2013. It was in there for about 4 days. Got it back and worked great. No noise/drone and no shutter. I have put on about 5K since. They replaced it with the new TC (not the reman'ed one). Glad I did it. The only thing different was that that the TC no longer unlocks when I engage tow/haul (it used to unlock, then relock).
Old 01-27-2014, 05:26 PM
FOZMAN11 FOZMAN11 is offline
Vehicle: 2011 Ram
Color: Hunter Green
FOZMAN11 is on a distinguished road
Question to the ones who had the TC problems. Did you have any other problems with your truck's trans (i.e. bad shifting, loss of MPG). Also, what rear-end gear are you running? My 2011 Ram has been problem free for 2 1/2 years and 23,000 miles, but in the last 3 weeks has not been acting right. The truck has lost ~4 mpg on the highway, it turns ~400 more rpms at 60mph, and it feels like its not shifting correctly. I took it in and was told it is shifting correctly according to the parameters in the computer. They did re-flash the PCM with updates, but it has not helped. The truck will run at 1500rpm at 60mph like it did all the time, till 3 weeks ago. If I pass another car or hit the gas, then it will run 1800rpm at 60 mph. It will return to 1500rpm at 60 after driving many miles or coming to a stop and restarting down the road. To me it is acting like the TC is not staying locked up or slipping. My Ram has the 3:55 rear-end gears.
Old 02-16-2014, 07:18 PM
S77R's Avatar
S77R S77R is offline
Vehicle: 2010 Dodge Ram 4X4
Trim Level: Crew Cab SLT BigHorn
Color: Inferno Red
S77R is on a distinguished road
As I posted in another thread I got my TQ replaced twice and it has been fine for the last year after the second replacement. I too though have noticed a loss in MPG after the TQ replacement. I keep track of my MPG each tank and over the last year I have avgd between 1-2 MPG difference with the new TQ. Dealer reflashed the trans etc, but it didnt change anything.
2010 RAM CrewCab BigHorn 5.7L Hemi - 3.92/LS
18" Boesch Muffler kit - Moroso Catch Can - Falken Wild Peak A/T3W 275/60/20
Old 03-02-2015, 11:22 PM
tomsram's Avatar
tomsram tomsram is offline
Vehicle: 2011 Bighorn
Trim Level: Bighorn
tomsram is on a distinguished road
Finally took the truck in for the Star case #112100005 issue. Dealer replaced with the re-man'd TC. Got the rumble as described in OP. Took it back today and they stated it is what it is basically. I showed where the Star case mentioned the "RL" and they said that's what they put in my truck. But they didn't according to my last service paperwork, the "R8" was. Also showed the email from an earlier post. They said they would re-order another TC, the "RL" this time... all without driving the truck. I was giving them a hard time but it seems they are at least doing something about it. I'll post when work done. Thanks for all the info!
Old 03-10-2015, 12:11 PM
tomsram's Avatar
Trim Level: Bighorn
Unable to send a pm yet due to newbie status. Will someone pm ArmyofOne for me?
Old 03-31-2015, 07:30 AM
Vinnie the Wrench's Avatar
Vinnie the Wrench Vinnie the Wrench is offline
Vehicle: 2012 Ram 1500 - QCSB
Rep:21
Vinnie the Wrench is on a distinguished road
ive had the rumble for awhile now, after reading this thread im nervous to take it to a dealer.
im curious has anyone installed an aftermarket or performance TC and had the same issues resolved? because if they are having this much trouble with their TC why not upgrade it and be done with it.
~Vinnie the Wrench~
Upgrades in the "Mods List"...
"....I will never leave a fallen comrade. I will never surrender though I am the last. If I am taken, I pray for the strength to defy my enemy...." -De Opresso Liber
