Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 04-27-2012, 12:14 PM
marcus2k2 marcus2k2 is offline
Vehicle: 2001 dodge ram
Trim Level: Base
marcus2k2 is on a distinguished road
Default 2001 5.9 oil pressure issue
I hava a 2001 dodge 2500. The oil pressure guage is not reading anything. I replaced the sending unit and have the same problem. What is my next step in determining if it is a bad pump, guage etc.
Thank you,
Mark.
Old 04-27-2012, 02:35 PM
MERF-09's Avatar
MERF-09 MERF-09 is offline
Vehicle: 2001 Dodge Ram
Rep:19
MERF-09 is on a distinguished road
pick up a oil pressure gauge & connect it to the 1/8" npt port were I have my Bypass filter line connected right next to the turbo oil feed line if it has oil pressure your gauge is bad on the dash if no oil pressure with the gauge you hooked up you need to check the oil pick-up tube in the oil pan and the Gear driven oil pump behind the crank case cover on the front of the motor.
One Owner 2001 3500 Cummins 320,000 miles & still growing & 2001 1500 5.2 92,000 & still growing
