Old 04-28-2012, 11:49 AM
cwbrow2's Avatar
cwbrow2 cwbrow2 is offline
Vehicle: 2010 Ram 1500 4x4
Trim Level: SLT Crew Big Horn
Color: Mineral Gray
Rep:18
cwbrow2 is on a distinguished road
Default How do u burp coolant system?
Installed 180 stat need to burp system, how do u do it.....thanks
Old 04-28-2012, 12:04 PM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
Let the truck run and then open up the coolant pressure cap (right above where you add coolant at) and your probably gonna half to do this 3-4x. Just open it, then you'll hear/feel the coolant equalizing through the system, and keep doing this until this stops. Check your coolant level after this and fill to the proper level.
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 04-28-2012, 12:35 PM
cwbrow2's Avatar
Color: Mineral Gray
Rep:18
Should rad hose be very firm or slightly soft to touch
Old 04-28-2012, 01:25 PM
Rep:111
I'm sure its soft until you get the coolant equalized through the system and should fill up the hose back up again, which probably would cause it to get more firm. Like I said just let the truck warm up in the drive way pop the cap off then put it back on and keep repeating until you don't hear the "gushing" noise. Shouldn't be to terribly difficult, just make sure you check your level and fill to the proper level after it's equalized.
Old 04-29-2012, 08:11 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
we also squeeze an release the hose a bunch of times during the same process to accelerate the process..
-fast freddie- one quick 05 hemi qc...with over 275k miles on odo... on the 5.7, stoker 6.4 now...Inertia Motorsports 392 stroker
Old 07-31-2014, 07:06 PM
B1500ram B1500ram is offline
Vehicle: 2003 Ram 1500 4x4
Trim Level: Quad cab/SLT
Color: Atlantic Blue
B1500ram is on a distinguished road
Hey guys, i replaced my water pump and thermostat today, but truck is overheating and the lower rad hose is cold to touch while upper hose is very firm and HOT! overheating. I have been trying to squeeze the upper hose to release the pressure but to no avail. Any ideas would be great! I have replaced the rad. in the past and had no issues with trapped air so i think i the bubble has to be near the pump.?
Old 08-01-2014, 12:53 AM
hemiheaven hemiheaven is offline
Vehicle: 2005 Dodge Ram SLT
Trim Level: Daytona
Rep:12
hemiheaven is on a distinguished road
sounds like a faulty tstat.
Volant PowerCore CAI, efan, 180 tstat, Pacesetter Lt's, Pacesetter y pipe, Hemifever 93 tune, 87mm throttle body, 4.56 Yukon posi.
Coming soon....Torque converter and drop
Old 08-02-2014, 12:50 PM
audio1der audio1der is offline
Vehicle: 2012 Dodge Ram
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
Just put my Jet 180* in yesterday; we alternate;y squeezed the upper and lower rad hoses (top, bottom, top, bottom..)
Got all but about a half quart of the coolant back in, and I wanted to throw a bottle of water wetter in anyway, so perfect. Ran at 185, saw 188 in bumper to bumper traffic. Truck is much peppier when at full temps; feels like driving in nice cool morning air all the time now. VERY happy with this mod!!!
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 08-02-2014, 04:31 PM
HammerHead's Avatar
HammerHead HammerHead is offline
USMC 0313
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
HammerHead is on a distinguished road
I did the 180t and refilled the radiator the next morning when the moto cold, is this the righ way? I tried to take the radiator cap with the truck running at normal operating temperature and had an explosion of hot radiator fluid bust from the system. Thankfully I was using a old tshirt and dident get burned. Did I over fill the coolant system?
Geared-Tuned(JG)-Shift Kit 14.0@96
Proud member of the 4 second club...
Old 08-06-2014, 01:43 AM
Rep:201
^Yes, it was good that you waited until the engine was cold to add fluid.
No, you just did a general no-no in pulling the cap. The coolant fluid expands as it gets hot, and the system is under pressure. Never open a rad cap on a vehicle at running temp.
