Old 04-29-2012, 12:59 AM
stretch0069's Avatar
stretch0069 stretch0069 is offline
Vehicle: 2001 Ram 2500
stretch0069 is on a distinguished road
Default Steering...question.....
Not sure where this goes......topics are a bit confusing, but since its a general question...here it goes....
I'm going to replace my steering gearbox with the Borgeson. Other than the possibility that the steering wheel might not be symmetrical, if I don't touch anything other than the Pitman arm, why would I need an alignment?????
I plan on doing due diligence in making sure that when the steering wheel is in the "normal"/"neutral"/"central"/"whatever they call it" position, my wheels are pointed straight ahead.
Am I correct in my thinking that as long as i make sure everything is centered (steering wheel, steering box, wheels, and Pitman arm) I should be ok?????
'01 Patriot Blue Ram 2500 QC V10
'15 Granite Crystal Challenger Scat Pack (on order)
Old 05-02-2012, 09:43 PM
snakepitt1's Avatar
snakepitt1 snakepitt1 is offline
Vehicle: 1997 Dodge Ram 1500
snakepitt1 is on a distinguished road
I'm getting ready to change out my steering gear box as well as nearly every steering component. So, I'll need an alignment for sure, but, even though you will be careful during your install, you will affect the alignment in some fashion. New front tires are very expensive. A front end alignment is not.
1997 Dodge Ram 1500 Extended cab. 360 Magnum, 2WD, It's no show truck, but it's my truck.
Old 05-05-2012, 11:23 AM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
Removing the pitman arm from the steering box where not affect the alignment. All adjustments happen at the tie-rods and the a-arms.
Old 05-05-2012, 12:20 PM
and that's the only thing being touched. if I was changing anything else, I'd definitely get an alignment. I'm about due for new tires soon so I'll just take care of it then.
Thanks!
