Old 04-30-2012, 04:02 PM
94ram2500magnum 94ram2500magnum is offline
Vehicle: 1994 Dodge Ram 2500
Trim Level: base
Color: Blue
94ram2500magnum is on a distinguished road
Default Turn Signal Fuse Blowing
Ok guys i fabricated and welded my own headache rack. It has two 6" oval LED tail lights. Ive wired them into the correct wires on the truck with quick connect splicers, now when the hazards or turn signals are switched on the turn signal fuse blows. And it wasnt blowing the fuse after i got it all hooked up it worked good for a while now it blows everytime did i wire it right or is it pulling too much power?
Old 06-04-2012, 05:14 PM
CARROLLX42's Avatar
CARROLLX42 CARROLLX42 is offline
Vehicle: 2004 dodge ram
Trim Level: Hemi Sport
CARROLLX42 is on a distinguished road
I would put a relay in there just to make sure. Also you may want to check for a wire that is grounding out.
SUPPORT YOUR LOCAL 16's
MC means club not gang.
