Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 05-01-2012, 01:08 PM
Miami Son Miami Son is offline
Vehicle: 2012 Ram 1500 Sport Crew Cab
Color: Mineral Gray
Rep:26
Miami Son is on a distinguished road
Default Speedo/odo issue
Hi guys, got a 1990 D350 with about 115k miles on her. The speedo works fine, but the odometer stopped working awhile back. Since there's no cable driving the two and the speedo works what should I look for? Is it likely something in the gauge cluster and is it fixable or should I look for a replacement? Any help appreciated.
Old 06-13-2012, 10:53 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Done and done. Look for another. As the speedo turns it also spins the odometer. As they wear sometimes the gear goes and stops counting. I was going to say it's a matter of mileage as opposed to age...but that's not entirely accurate since different climate conditions (Death Valley)have different effects on the original lubrication.
Kinda like putting new brakes on your truck and then driving cross-country the next day non stop. Some might say that their brakes have 5000 miles on them when they actually probably have about a half mile on 'em.
If you want to save some time, try Car-Part.com. It's a used parts locator that checks (inventoried) stock in scrap yards on the Hollander and Pinnacle system used between scrap/recycling yards.
Old 08-28-2012, 10:14 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
I was working on mine but it was a different issue. Mine works when it wants to. The oerdrive goes away at the same time. Since the speedo is electric speedo so I have an idea what and where but time to get to it. WarlockIII I like your stepside body.
Where steal it from???? Ha Ha.
Old 10-01-2012, 01:31 PM
hemiram66 hemiram66 is offline
Vehicle: 2004 Dodge Ram
hemiram66 is on a distinguished road
There are two gears that are your problem. You can get those here:
http://www.odometergears.com/product...ept+Monaco/125
There are probably some guys on other forums who did an install but i guess Youtube also works:
Oldy, your odometer motor is probably going. Ask around diesel truck resource or check ebay to see if you can get one
Old 11-20-2012, 01:15 AM
1993 ram 150 1993 ram 150 is offline
Vehicle: 1993 ram 1500
Trim Level: power everything
Color: blue /silver
1993 ram 150 is on a distinguished road
Default Speedo / odometer issues
I have just the opposite problem. My trip and odometer work fine, but speedometer is inop. no jumping, just reads super slow ( going 70 using my gps, speedo may say 12.5 ) or stays at 0. any one have any ideas? mines a 93 with a 5.2 gas motor automatic.
Old 11-20-2012, 05:10 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:93
Ooops, wrong thread. Posted reply. my goof.
Old 11-23-2012, 02:44 PM
marnell79 marnell79 is offline
Vehicle: 1993 b350 cummins
Color: lots
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
marnell79 is on a distinguished road
check the ratio drive adaptor its right off the trans the problem is the shaft wears out and it stops or you have a bouncing speedo or it reads really slow. I took mine out and just screwed the speedo sender straight into the trans and It starting working again problem is now it reads 87mph at 55. so its pretty far off and finding one is no easy task. Ive looked on-line and at the dealer (who have no clue)
Old 03-15-2016, 05:16 PM
gwgdog66's Avatar
gwgdog66 gwgdog66 is offline
Vehicle: 1990 Dodge Ram D100
Trim Level: Base D100
gwgdog66 is on a distinguished road
I apologize for digging up an old thread. I have a 1990 D150. with the same symptom. Speedo works, but not the odometer or trip meter. Does the D150 share the same speedometer as the one referred to in the video?
Thanks
Gary
Gary
OKC, OK
