Old 07-11-2012, 09:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Yes fastnugly, that's what I use. I pour about a cup or so(just pour for a second) into a bucket, then usually also pour some general car wash soap(cheap stuff from autozone or walmart) in as well, then fill the bucket with water and that's what I use to wash the truck, including wheels and wiping down the tires. I try to take the wheels/tires off the truck every couple washes and wipe them down backside and all, to keep the tires from dry rotting. I will also use the same stuff on a clean rag on the dash/interior(don't get it too wet...wring it out real good). Basically I use it on everything except fabric. I will say the oil soap might leave a slight haze look to the paint and doesn't quite look as appealing as some of the fancy wax/polish/seal jobs you see, but it protects well and that's really all I care about. It still looks good IMO. You have to REALLY look close to notice those awesome wax/polish jobs, and I just don't care about that on my DD.
Sean
Old 07-11-2012, 09:45 PM
snrusnak's Avatar
Rep:1385
hnrypat, what about like a bright blue or something like that, to avoid looking so "funny" with a "girly" color?
Sean
Old 07-11-2012, 10:27 PM
TimW's Avatar
TimW TimW is offline
Vehicle: 2012 Dodge Ram
Trim Level: sport
Rep:161
Just got back from the cottage, dirt roads, mixed with tire shine spray up on the body, makes for a nice mess, and yeah it was being flung up the side of the truck, there is an area at the bottom of ther flare where the tire sticks out farther.
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
I say go with the hot pink
You will just look way too cute going down the road
Awww hell, maybe pink with purple poka dots...yep thats it
MATT
Old 07-11-2012, 11:32 PM
Rep:1804
Thanks!
You got a white truck which hides many things. So if you can see a slight haze....how would it appear on black?
Old 07-11-2012, 11:33 PM
Rep:1804
LOL!
Stick with the pink and that tag you have will surely mean business
Old 07-11-2012, 11:34 PM
Rep:1804
Ouch!
I jus sprayed tire shine on mine. Now I got it on my truck too from spin off
Old 07-11-2012, 11:35 PM
Rep:1804
Ahahahahaha!
The purple polka dots is one too far.
I honesty. I wouldn't do pink but it won't look that bad
Old 07-11-2012, 11:53 PM
Rep:1804
Default Reverse HIDs - INSTALLED
Sooooo....
I finally got around to installing the reverse HIDs and they are BRIGHT as f&ck!
I will still be adding a switch to it to blind those tailgaters
Quite easy to do, just never found the time till today
They are low wattage at 15W so hopefully the housing doesn't melt.
Many claimed it doesn't. No ne has claimed otherwise.
For those of you who don't know, the taillight is held by 2 x torx screw (can't recal the size)
This is the before
Once remove - this is what it looks like
This is where I mounted the ballast via double sided 3M
The reverse harness will need to cut off or spliced into. I cut it off for ease but left enough so I can reattach if need be
Connected both together and taped it up. I used dielectric grease on the connection to make sure it doesn't corrode
Before (right) and after (left)
I know it's bright out....hard to compare
Repeated same steps on the passenger side and here is the end product
Old 07-11-2012, 11:58 PM
Rep:1804
Default Reverse HID night shots - off/on
Took a night shot as that's what you all want.
I did not remember to take a before of the factory reverse the night prior as I did not know I was going to install them today
But you can all check your stock halogen and compare to these spot lights.
Off
On
Before and After
