Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 05-01-2012, 02:04 PM
CJH's Avatar
CJH CJH is offline
Trim Level: 4 x 2
Color: Charcoal
CJH is on a distinguished road
Default Has anyone run E85 Flex Fuel in their Ram?
Has anyone put E85 Flex Fuel in their Ram?
I'm playing with the idea with the price of gas the way it is. It's 50 cents cheaper a gallon here in Ohio.
I've heard that the mileage and performance drops though and that in the long run you don't save a dime...
Just curious....
Thanks
Old 05-01-2012, 04:54 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Just curious....
Thanks
I was thinking about it but it' not a good idea especially since you have to modify the vehicle a bit.
Here are modifications that need to be done and it's expensive.
1. Need to change the fuel pump so it can handle Ethanol, Ethanol isn't die-electric like gasoline so if you put it in a vehicle that doesn't have a designed fuel system for ethanol then you risk igniting the gasoline.
2. You need to change the fuel lines to handle ethanol
3. The A/F ratio for ethanol is slightly higher then that of gasoline so you need to program the ECM for ethanol
4. You don't get better MPG so if you do the math the cost in terms of MPG and distance traveled is going to balance out. The implimentation of ethanol was to reduce emissions, not save money (damn government).
I personally was trying to find gasoline alternatives that are extremely cheap but so far I haven't come up with anything solid enough, I also would need to test it and put my life at risk doing it but hey if it costs 10 cents I'm wearing one of those lava suits :P
Old 05-01-2012, 09:00 PM
bhepper bhepper is offline
Vehicle: 2014 Ram 1500
Trim Level: CC Outdoorsman 6'4"
Color: Silver w/Black 2 Tone
bhepper is on a distinguished road
Just curious....
Thanks
It use to be that unless the E85 was $1 cheaper per gallon it wasn't worth it. Would assume that's still true but it might not be. Not sure if you would necessarily lose power with E85. There are some manufacturers that claim higher power numbers with E85.
2014 Model - MFG: 0914 & MDH: 091713 - A Wednesday @ 1:00pm truck!
Old 05-01-2012, 09:07 PM
ramvan2500's Avatar
Rep:128
You would loose HP because of the evaporation of ethanol vs. gasoline also the energy potential and the A/F ratio, like said with ethanol you need a slightly higer A/F ratio. But unless the fuel system was designed for E85 I would advise against putting it in the tank even if it was cheaper and got better performance and MPG then gasoline.
Old 05-02-2012, 08:11 AM
Black1 Black1 is offline
Vehicle: 2012 Ram 1500
Black1 is on a distinguished road
I've never seen E85 and wouldn't know where to get it.
Old 05-02-2012, 09:01 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
I run E85 regularly in the city in my 09. Anything 4.7 thats 08 or newer is factory equipped to run ethanol with no modifications.
I actually notice a slight power boost on E85. Truck drives differently. Its weird. 9-10mpg city isnt cool, but as long as city driving is all we are doing that week it doesn't really matter, not much difference between 9 and 14mpg, especially when you consider I have to fill up weekly, regardless, and the price is significantly cheaper where I am.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 05-02-2012, 09:40 AM
CJH's Avatar
CJH CJH is offline
Trim Level: 4 x 2
Color: Charcoal
My 2010 is equipped from the factory to run E85....
I might try it for a week...9-10 MPG though doesn't sound like a good investment....the majority of my driving is city driving.
Right now it is averaging $.50 per gallon cheaper...
Old 05-02-2012, 09:59 AM
RAMROD5's Avatar
RAMROD5 RAMROD5 is offline
Vehicle: 2006 Dodge Ram 3500 Dually
Rep:13
RAMROD5 is on a distinguished road
not much of a difference between 9 and 14 mpg? LOL interesting.
2006 Ram 3500 Dually, 5.7 hemi.
Old 05-02-2012, 03:44 PM
ramvan2500's Avatar
Rep:128
I notice they sell it in the southern states mostly and in the mid west, anywhere they're going to grow corn just about. But the true implimentation of E85 was specificially for emissions not for economy or anything like that.
Old 05-02-2012, 03:50 PM
ramvan2500's Avatar
Rep:128
When I was speaking of modifications required that is if the vehicle isn't equipped for it, I am not aware of what models and years of dodge's are equipped.
Well anyways ethanol is ok nothing wrong with it but truely more energy potential in gasoline then ethanol also gasoline has a natural lubricative property which means the engine will last longer but that's why E85 is E85, 85% Ethanol and 15% Gasoline.
The real issue is the A/F because you need slightly more fuel with ethanol then you would gasoline. To be honest I would much rather prefer ethanol over gasoline in terms of price and supply but thing is oil companies are involved so the price will always be within the same range as gasoline. That and you always have your backyard geniuses.
