Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 05-01-2012, 02:05 PM
Tim28's Avatar
Tim28 Tim28 is offline
Vehicle: 2010 Dodge Ram Laramie Quad Ca
Rep:33
Tim28 is on a distinguished road
Default Air Lift vs Timbren Helper
Hey guys. I'm having my truck leveled with the Bilstein shocks set to 2.1 but I realize that when I tow my 6500lb boat I may have the rear slightly lower than the front... Not acceptable! lol
So I've looked into both the Timbren Helper springs and the Air Lift system. Which do you suggest? Which did you choose? What are you happy with? Pros/cons?
Thanks in advance!
*Someday I'll have enough posts to have a real signature*
Old 05-01-2012, 02:40 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:358
I went with the Air Lift. At $87 delivered I figured even if it sucked I wasn't out of anything. It does not suck. It couldn't be easier to install. No sag with my 6500lb trailer. I love it.
333 Half the beast
I used to be
Old 05-01-2012, 03:38 PM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
I just got the TLC air springs. Man what a difference.
Old 05-02-2012, 12:26 AM
Tim28's Avatar
Rep:33
So you replaced the entire rear coil spring? What kind of a difference do you feel?
Old 05-02-2012, 06:34 AM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
I went with a set of springs from topguncustonz. They are the same height just a bit stronger. When installed they lifted the rear of the truck 2 inches. And in my opnion i have a better ride. I have bilsteins set at 2.8 and bilsteins in the rears. I still have a slight rake but the truck is lifted. When I tow and the bed is packed with gear I'm sitting level. And the ride is day and night.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 05-02-2012, 07:19 AM
y2kflhr y2kflhr is offline
Vehicle: 2011 Ram
y2kflhr is on a distinguished road
I went with the air lift for when I carry my bikes in the back, I haven't used it yet so I can't comment on how well it works but it was pretty easy to install. It was also a few bucks cheaper if you call autoanything and tell them you are a member, I think I saved an additional 5 bucks under the 87
I wonder if you guys change your tire air pressure when you load up?
Old 05-02-2012, 09:55 AM
thiggins's Avatar
Rep:44
The TLC air springs don't replace the coil springs. Your stock suspension is
left alone (save removing those cheap plastic bump stops).
The TLC air bags are installed where your bump stops are after you knock them out with a whiffle bat. They are large "bus" type goodyear bags and supplement the coils. Each bag is rated for 2500 lbs, so it's really overkill, but with the compressor I can adjust the height of the bed at will depending on the load I'm carrying. I tow a trailer and load up the bed, so it will be awesome for me. Once I install the controller inside the cab it will be a couple of button pushes to put it where I want it. It makes the truck feel more "sporty" too, really firms it up, but not a harsh ride.
Old 05-02-2012, 02:36 PM
Tim28's Avatar
Rep:33
[Note to self, google before asking dumb questions.] This really looks like the way to go. The more expensive way to go but definitely the most complete.
For those of you using a system of some kind, is your truck leveled and does it stay reasonably leveled?
Thanks for the feedback so far!
Old 05-02-2012, 08:52 PM
semperfi's Avatar
semperfi semperfi is offline
Vehicle: 2014 2500 Longhorn 6.4 Hemi
Trim Level: Longhorn
Rep:18
semperfi is on a distinguished road
I have TLC. With 5lbs it raises the rear 1 inch, but I can raise the rear another 4 inches by putting more air in. I'm waiting for my Bilstein 5100s. I have had air bags on the last 4 pickups I have owned. When I loaded my Polaris 850 sportsman in the back without TLC it sucked the ass down 4 inches, now I push a button and it levels or goes higher.
Traded 2012 1500 Longhorn 5.7 Hemi
Old 05-03-2012, 08:52 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Airlift 1000's here. Had them for over a year, probably longer. No issues and initial purchase price is hard to beat.
I haul 'Cruiser' MC's. Vulcan 900 in the bed and a Yami Stratoliner in a trailer, or, most recently a Yami Roadliner in the bed. No difference. Level as can be.
I'll run 'em at 30 psi loaded heavy and 0 psi empty. (Yeah , I know, not supposed to go less than 5)
The 'available' air suspension on the 13's looks attractive.
