Old 05-01-2012, 05:18 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Exclamation fuel leak at tank
Ok the 95 4x4 has a leak at tank. Now this is what I found I filled it up and accedently over filled it that's when I noticed it so I thought ok neck leaks. Well its been a while now and dad and I have put 50 miles on it and its down 1\4 of a tank. Well drove it today and well leak. So now I stuck my head under the bed its leaking around fuel pump so loosend fuel cap and it releced 2 sec worth of pressure. So I looked into evap system and was wondering if a bad purge valve can cause an over pressure like this?
Old 05-01-2012, 05:32 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
It should leak period, even if the vehicle was to roll over the fuel shouldn't leave the tank PERIOD. If it's leaking around the top of the tank at the pump I could honestly put my money on a leaky fuel line quick connect, they're made of nylon and this part is known to crack on the dodge's after some time, if not that then could just be old cracked rubber hoses just drop the tank put a new pump in clean the tank new grommets call it a day.
Old 05-01-2012, 05:54 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Well I was hopeing not to remove bed. My first thought was gasket at top of tank. But I noticed it was bubbleing out from pressure. And haveing 3\4 of a tank of fuel in tank and only being driven less then ten miles I don't think it should have hissed at me like a mad snake when I opened cap? My 01 never hisses when cap is opened at any time?
Old 05-01-2012, 05:58 PM
ramvan2500's Avatar
Rep:128
Well gasoline vaporizes at a very low temperature, less then room temp. Besides the point, some gas caps has pressure relief valves built in also the evap system should handle the pressure. But it shouldn't be leaking, so you're probably going to have to drop the tank (or remove the bed).
Old 06-06-2013, 03:57 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Default solution found!
Well as discribed earlyer the truck was building tooo mutch pressure in tank causeing a leak at fuel pump. Well after a little time and some hunting and finaly 65$ for a specal order part it was purdge silnoid not letting pressure out of tank through evap system.
Old 06-06-2013, 04:02 PM
ramvan2500's Avatar
Rep:128
I must say that I am surprised, the check engine light should have came on if that solenoid failed... Interesting it didn't, well computers what can I say. I too am having an issue with pressure build up in the tank, Chrysler engineers so graciously placed a black fuel tank directly at the rear of the vehicle, behind the axle and exhaust. It is always nice to unscrew your gas cap and hear PFFFFFFF!
Old 09-24-2013, 11:49 PM
Rtbacca Rtbacca is offline
Vehicle: 1996 dodge ram 2500
Trim Level: Laramie Sport
Rtbacca is on a distinguished road
I have a leaky tank when full and will be placing the fuel pump soon because it is running low pressure. I assumed that the leak was coming from the top of the tank of the gasket around the fuel pump but after reading this forum I was wondering if I should look into this selonoid you ordered? and was wondering where you ordered it?
