Old 05-01-2012, 07:41 PM
snakepitt1's Avatar
snakepitt1 snakepitt1 is offline
Vehicle: 1997 Dodge Ram 1500
snakepitt1 is on a distinguished road
Default Fixed to sliding rear window change out
I changed a fixed rear window out for a sliding style rear window on an old ford ranger truck many moons ago. Has any one done this conversion on a 1997 Ram 1500 extended cab? I was wondering how hard it was and if there were special tools or sealants required.
1997 Dodge Ram 1500 Extended cab. 360 Magnum, 2WD, It's no show truck, but it's my truck.
Old 05-05-2012, 07:32 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
It is a PIA I have had too windows changed from slider to solid and both times the window glass installer was pissed when he found out it was a 2nd gen Dodge they told me they are among the toughest truck ones.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 05-05-2012, 10:46 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
They are sealed in and a pain to get out. Standard window urethane to install. It can be purchased in a caulking tube at a decent supply store.
If you're going to replace it with a used one you can use the '94-'97 double slider, or the '98-'01 single slider. The footprint is the same but the options lead used parts sellers to tell you yours is '98-'01 because of the different panes.
