Old 05-24-2012, 10:27 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
This is great information Ramvan2500. I'm one of those guys you call "knowledge of many...master of none." As I get older I still want to learn more and work with my hands. Just learn HVAC over a year ago, planning on taking classes in welding this fall, then would like to learn and rebuild my own transmissions. Just like doing my own work on things. Problem is you become everybodies friend but thats ok...I like to help people out.
Old 05-24-2012, 10:31 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Thank you. Welding is pretty fun to learn, you could teach yourself of course go to harbor freight, buy one of those electric flux core welders. It's a start!
HVAC is good field to be in, especially since summer is right around the corner. But umm, if you want to learn to rebuild transmissions I'm here to help if you need any. Hect you can pick my brain about anything, anytime!
Old 06-14-2012, 01:12 AM
bigmikelrg's Avatar
bigmikelrg bigmikelrg is offline
Vehicle: 1999 Dodge Ram 1500 Sport
bigmikelrg is on a distinguished road
Yea so I went to go and monitor the tach like u said ramvan and it's doing something different now now it's shifting late through all gears just CRUSING and when I get on it it passes the red line and hits the rev limiter at 5500 RPMS I have to let off the gas for it to shift and it bangs on the rev limiter 3-5 times if u let it is that the oil pres solenoid and is it possible to do a 50/50 race/daily driver internals with my trany and if so can I have par numbers I know ur notorious for trannys but if it's not possible can I have part numbers for trany rebuild parts to make it as much like a race tranny as possible but still b able to run as daily driver? Thanks ramvan!
HyperTech Power Programmer, PowerAid Throttle Body spacer, BOSH Plugs, Super40 FlowMaster Exhaust
Old 06-14-2012, 01:46 AM
ramvan2500's Avatar
Rep:128
Oh yes of course, I will give you the parts and there part numbers for a daily driver rebuild that allows you to do light street racing, you won't be able to throw 400HP behind it without snapping a shaft or hub but you can stomp down on that pedal over and over and over and over and not have to worry about a thing.
I will begin making a list tomorrow morning and probably have it up tomorrow night, it's a relatively short list. I do have a couple of questions just so I give you the correct parts, What year is the truck and what model transmission do you have, I think you once told me it's a 46RE???
I need to know year and model because different models and years used a different number and thickness of friction discs and friction plates.
What is the predicted HP you are putting into it? Do you plan on doing many many burn outs? Do you expect to tow often or moderately? Are you going to be doing high speed racing?
I have to get a tach, I have my heart set on a autometer 5" with a shift light and built in memory. But thats almost 200 bucks! Ouch...
Old 06-14-2012, 02:30 AM
bigmikelrg's Avatar
Tach is cool I need one right. AND yes towing every now and then nothing to big and it's stock engine right now and it's a 1999 5.2 I'm not sure the moddle trans but on the info sticker under the hood the code for the trans is (DGB, STD DUTY 4SPD AUTO TRANS) I think it's a 46 or 47 I'm not 100% sure but if u need one ofe the letters off the vin that's fine and I eventually want to drop in a 5.9 stroker but by then I will b wanting to switch up the tranny even more and yea burnouts when I want so yea the capability to do that I also have 4:10 gears in it if u need that info aswell.
Old 06-14-2012, 02:35 AM
ramvan2500's Avatar
Rep:128
The 46 series transmission is actually very strong transmission, remember that a transmission is rated x ft-lbs that is constant load under shock load conditions you can reach almost 5 times the constant.
But I'm very sure you have a 46RE, finding a 47 series isn't common except in the 2500 series and behind the 5.9L most times if it's the 5.9L and 47 combination it's in a 2500 series. But this information is good enough, umm how much you plan on spending?
Old 06-14-2012, 02:58 AM
bigmikelrg's Avatar
I know I'm going to b rebuilding a tranny so it's not gona b cheap but I don't wanna buy 24k gold parts I'm fine with sterling silver u get wat I mean not top TOP of the line but good enough for durability reliable and and handle some raceing
Old 06-14-2012, 11:09 AM
ramvan2500's Avatar
Rep:128
I understand 100%, I got a called in so I have to go to work but I will have the list sometime tonight.
Old 06-14-2012, 09:09 PM
ramvan2500's Avatar
Rep:128
The list is going to have to wait another day or two, I just had a front wheel bearing go out on me along with another wheel stud and wheel nut and all 4 wheels out of balance again. Damn truck has been costing me alot of money and pain.
Old 06-15-2012, 06:34 PM
bigmikelrg's Avatar
O ok just leme know
