Old 05-02-2012, 12:11 PM
Pancho Coddou Pancho Coddou is offline
Vehicle: 2011 reg cab ram SLT 4x4 5.7
Pancho Coddou is on a distinguished road
Default Would this work?
Hi, i have a 2011 ram sport 4x4 hemi, i was thinking about this setup:
BFG 285/65 r20 on stock wheels (those are 34,7 x11,5)
1/4" wheel spacer
Bilsteins 5100 at 0,7" or 1,4" (as little as i can)
What do you guys think? would that rub? im really scared about getting vibrations if i go any higher than that.
Its not for off roading, but it will see some bad terrains from time to time, i use the truck to go camping with a lot of heavy stuff in the back (arround the payload limit) and as a daily driver so i need it to be reliable.
Thanks.
Old 05-02-2012, 06:37 PM
SolidRam's Avatar
SolidRam SolidRam is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Lone Star Edition
SolidRam is on a distinguished road
Check this website out, I have it bookmarked for reference, very useful
http://www.readylift.com/t-tire-calculator.aspx
Old 05-02-2012, 07:25 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
If you have the chrome clad 20's that sports come with then the BFG 285/65r20's will fit fine with no rubbing. I had the same tires on my chrome clads last year and they were great. I had my truck leveled and didn't need a spacer, so if you install the 5100's you shouldn't need a spacer either.
Old 05-06-2012, 07:09 PM
Dos the 285/65 fits under the bed? did you notice any hits on the MPGs?
Old 05-07-2012, 06:45 PM
Rayne's Avatar
Rep:73
I never tried putting one in the spare tire spot so I'm not sure. There was a slight hit on the MPG's but nothing too drastic.
