Place your Ad Here!
Old 05-02-2012, 11:12 PM
DenDen's Avatar
DenDen DenDen is offline
Vehicle: 2011 ram 1500 4x4
Color: Hunter Green
DenDen is on a distinguished road
Default trouble starting
This morning I go to start the truck and it would just start to turn over but wouldnt start.Sounded like it had a dieing battery.So I try the horn and its working.Tried it again and it went no problem.Started it after work and it fired up like its supposed to.Next time I try to start it(sitting in front of my garage again)same problem.took the key out,then back in same thing happening.Then it started,quickly as if there was no problem.No codes came up.Battery conns look good,tight. Any insights?
2011 Dodge Ram.Hunter Green Crew Cab,Hemi.20 inch wheels.Bought August 28 2011.
Old 05-02-2012, 11:20 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:778
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
check your ground connection. follow the black cable to the other end.
Old 05-02-2012, 11:23 PM
DenDen's Avatar
Color: Hunter Green
good idea,I'll try that
Old 05-03-2012, 10:40 AM
Rep:778
let us know what you find.
