Old 05-03-2012, 09:12 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Default Stock 6.4 Cam/Cam Phase Limiter
Well i think i just found the next big mod for you 09-10 guys take a look at this.
http://www.trademotion.com/parts/201...20%26%20TIMING
At $57 for a stock 6.4 cam and $100 for a compcams phase limiter this thing could easily make 50hp with a good tune. There will be no more piston to valve clearance issues!!! This is a no brainer mod guys!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 05-03-2012, 10:28 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
you may have seen my old thread about this....without the phaser limiter it dont work....never updated but i have the cam and the phaser limiter just trying to find the time....i have some days off around the 21st of this month and thats when i plan for now on doing this.....jba shorties at the same time...anyone else try this yet?
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 05-03-2012, 11:25 PM
RamTex's Avatar
Color: Stone White
Rep:366
What is the lift on it? MAKE SURE YOU DO A BEFORE AND AFTER DYNO!!! That will tell the whole story!
Old 05-04-2012, 10:10 AM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
Originally Posted by ramtex View Post
what is the lift on it? Make sure you do a before and after dyno!!! That will tell the whole story!
6.4 with mds......
Total duration....
Intake 286 open@36*btdc/closes@250*atdc
exhaust 288 open@278*btdc/closes@10*atdc
46 deg overlap
lift@valve w/0lash
intake .577
exhaust .537
no idea what duration is at .50 lift and its not just as simple as doing the math......thats where the voodoo is.....
09+ truck 5.7 with mds
total duration
intake 268....opens@28.2*/closes@239.8*
exhaust 290....opens@274.2*/closes@15.8*
44*overlap
lift@valve w/0lash
intake .472
exhaust .460
Old 05-07-2012, 06:29 PM
irnwkrkev irnwkrkev is offline
Vehicle: 2011
Trim Level: Longhorn
irnwkrkev is on a distinguished road
I've looked into this after reading this post and have found some interesting facts.
1. The 6.4 uses different lifters (probably to handle the increased lift and still function with the MDS). $97 X 4 (sold in sets of four- 2 front and 2 rear).
2. The springs are different. Again, probably for the increased lift. The retainers and locks are the same but I don't know if the seats are different. Around $180
3. solenoids for MDS are the same
4. pushrods and rockers are the same which makes me think that the valves are the same height unless the 6.4 has a different deck height.
Seems like it's going to be a lot more then the $150 cam swap I did with a ZR1 cam in my SS Camaro but the gains will probably be alot more then the 20hp I gained as well. Too bad I can't tune my 2011 to be able to perform this swap .
