Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > AutoAnything - Dodge Ram Accessories! - Dodge Ram Performance!
AutoAnything - Dodge Ram Accessories! - Dodge Ram Performance! Shop AutoAnything.com for thousands of top-brand automotive and truck performance parts and accessories. Free shipping, great prices, all backed by AutoAnything's 1-year lowest price guarantee! To order, call 1-888-591-8563, Click-to-Chat, or visit www.autoanything.com. - Dodge Ram Performance - Dodge Ram Accessories!
Old 05-05-2012, 11:59 AM
ArmyofOne's Avatar
US Army Retired
Rep:1189
Default Clark...do you guys do brakes?
Gonna need pads soon (front and rear) and thinking I might upgrade to slotted and drilled rotors to assist in stopping the 7k lbs worth of boat I will be towing...
Diesel Technician-PACCAR Inc.
Old 05-05-2012, 12:23 PM
Rep:2616
http://www.autoanything.com/brakes/10A50530.aspx
Old 05-06-2012, 09:42 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Maybe an Autoanything Ramforumz brake special. Seems like I've seen a couple people talking about brakes lately.
Old 05-06-2012, 10:01 PM
GreatTiger's Avatar
GreatTiger GreatTiger is offline
Vehicle: 2011 Ram 1500 SLT
Rep:31
GreatTiger is on a distinguished road
I know it's my turn to do my brakes i'm interested in EBC's brake parts. Reviews on them seem pretty good. I can't find any info on EBC's site as wear to get them in Canada though. You guys ship to Canada?
Old 05-06-2012, 10:30 PM
I push the skinny pedal
Rep:3277
I actually had my EBCs showed to canada, so you should have no issues. As for the brake upgrade, stay away from drilled rotors, they have known cracking issues and they do NOT increase braking power, only upgraded pads, more pistons in the caliper, or larger rotor diameter will increase braking power.
Kurtis
Old 05-07-2012, 12:02 AM
ArmyofOne's Avatar
US Army Retired
Rep:1189
Not true. Slotted/Drilled rotors from reputable companies (PowerStop, PowerSlot Brembo, StopTech, EBC, etc...) are usually ok. I can't speak for their use on trucks, but I know on my civic I had OEM replacements from PowerStop that were drilled and slotted, cost me $100 a piece and stopped that car so much faster than stock.
I am not looking for something to stop me faster, I am mainly looking for something that looks better, but performs at least as good as stock, maybe a little better. I don't tow the boat all the time, so I am really just after the looks department. The rotors I had on my civic were 2 years old when I traded it on my Ram, they had 50k on them, weren't warped, and not a crack that I could see.
So far, seems like the best deal:
http://www.autoanything.com/brakes/6...0A3121093.aspx
But then I found them here cheaper.
http://www.discountbrakes.com/shop/?...ke,universal:0)
After I did the math though, with AA's free shipping, they come out on top by like $50. I am looking at doing just the fronts now, and the rear's when I get to that point.
Old 05-07-2012, 12:26 AM
Rep:3277
Actually, it's the design of the drilled rotors that is the issue, not the manufacturer. A cross-drilled rotor was originally designed to channel the gasses from the pads away from the rotor surface to dissipate gas-induced brake fade. The modern pad materials do no off-gas like the old materials did, so having cross drilled rotors is useless, and they don't keep the rotor any cooler since there's less surface area to absorb/dissipate heat.
Also, anytime you have a surface interruption in a heat cycled material you have what is called a thermal ridge where the opening is trying to expand outward, while the material is trying to expand as well and the opening is where it will expand into first; you have two heat stressed surfaces trying to occupy and this thermal ridge is formed and it's the place where micro fissures will occur, and these propagate into cracks. Unless the rotors have been cryogenically treated and then heated to their eutectoid point where the alloy's crystal structure will begin to blend, increasing the substrate area and reducing the surface tension, then the rotors WILL eventually crack.
They did great on your civic because your not trying to stop 5,900lbs of steel like you are on a truck. I inspect my rotors 3 times a year for crack propagation, and so far so good, but I'm running dimpled/slotted rotors, not true cross-drilled ones which are more likely to crack.
I can say that the rotors won't do anything for performance, but I do run the EBC sports rotors because of their looks as well. The G/S pads are still my favorite and they do make a difference over stock with great wear characteristics. I personally run the G/S 7000 Supremes on the front and the 6000 on the rears because the 7000 are a harder material and last longer.
Kurtis
Old 05-07-2012, 02:40 AM
GreatTiger's Avatar
Rep:31
Jey CdnOilRam, how much was shipping and duty?
Old 05-07-2012, 09:44 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I thought the only reason for cross drilling(or slotting, etc.) was to keep the rotors cool, through better heat dissipation to the air? One would think they'd technically provide less stopping power(due to less contact between the pad and rotor). If they are not actually better why do all the supercars have cross drilled rotors? My buell has drilled rotors as well.
Sean
Old 05-07-2012, 12:26 PM
AutoAnything's Avatar
AutoAnything AutoAnything is offline
Your Mod Superstore!
Vehicle: Full Garage!
Rep:165
AutoAnything has a spectacular aura aboutAutoAnything has a spectacular aura about
Please PM me for a quote and I am looking to see what kind of brake promo we can do on the Z!
We do ship to Canada too, thanks everyone.
Clark-
Click the ^banner^ and save up to 16% OFF Orders Above $150 on Dodge Ram mods.
We price match, simply call 888-591-8563 or
Click-Here-to-Chat and we'll beat ANY price by $1.
Click Here To See The Latest and Greatest Specials From AutoAnything!
