Old 05-06-2012, 09:41 AM
CIRCUIT BREAKER CIRCUIT BREAKER is offline
Vehicle: 2001 Dodge Ram
Rep:13
CIRCUIT BREAKER is on a distinguished road
Angry Please help another wont run !
01,3.9,104,00 miles....This is the problem,cold or hot no difference, shuts off at idle like you turned the key off, may idle perfect 5 min. or 10 min. ... Driving down road any speed a few feet or 20 miles, engine dies but restarts itself.. ( chugs) check engine light will flash a split second before it dies. Been working on this for over a month. No engine codes..
This is what I have done...
Dist. cap .... Rotor... Plug wires... Plugs...
Crank shaft sensor ( twice )
Dist. pickup ( cam shaft sensor) ( twice)
Map sensor
Air intake sensor
Fuel pump assembly--and ing. coil
Cleaned IAC and intake
Checked---- Vacuum ( steady 19 to 20 )--- Batt. voltage to computer 12 volt constant--Keyed 12 volt correct--5 volt sensor supply good..all grounds good( coming out of computer) and engine,chassis...Checked ALL wiring a bunch of times,Battery good (load tested) Alt. good and charging
Sorry for long post, wanted to give enough info.
Any way to check the computer at home??? Should this be the next step?? Hate to go to the dealer and be ripper off, I am a die hard do it your selfer..
Thanks for your help.. GREAT FORUM !!!!
Old 05-06-2012, 10:06 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Try to test fuel pressure. The pump or morelikely relay is becomeing hot and is shorting.
Old 05-06-2012, 03:01 PM
Rep:13
Thanks for the reply,however this is not the case. The fuel pump is not cutting off until after the motor dies one or two seconds,then the ASD shuts the fuel pump off via fuel pump relay. When engine is no longer running(not firing) the computer activates the ASD. This circuit is thus working the way it is suppose to.Thanks again.
Please need more help!!
Old 05-06-2012, 04:42 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Well the only way I can see to test computer is to rent a code scaner from an auto parts store. It might be a deposet charge but cheaper then stealership.
Old 05-06-2012, 08:35 PM
Rep:13
Thanks again ramfam. I have a scanner but it won't check the computer it self. It will communicate with the computer but it can not tell you if the computer is doing it's job. Auto zone or any of these type stores do not have the equipment to check the computer. They can only read the data stored in the computer. ie codes. I read somewhere on this forum that there was two pins on the computer you could jump out and it would do a self test. I have read till I am cross eyed but can not find it again. I did check fuel pressure it was good, but put in a new pump any way. I did not make that very clear in my post. Thanks again. I need help !!
Old 05-06-2012, 10:15 PM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500, 2001 Ram 1500
Color: 2500 White, 1500 Black
Rep:97
SnoopyIsMyHero will become famous soon enough
You said you cleaned the IAC, but is it any good?
2001 2500 5.9 4x4. Stock except for exhaust, step rails but I don't care, I love my beast
2001 1500 5.2 4x4. Stock except for exhaust, my new project.
Old 05-07-2012, 02:03 PM
Rep:13
Yes iac working ok. Engine will die even running interstate speed, but will instantly restart itself. This thing is really being a pain.. NEED HELP.. Thanks for reply..
Old 05-13-2012, 08:59 AM
Rep:13
Problem solved.. Installed new COMPUTER.. Ordered from Florida.. $180.00...$20.00 second day shipping..Life is good. Thanks for your help....
Old 05-13-2012, 09:53 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Circuit Breaker. I just happened to run across your thread and wish I would have earlier. I had the exact same problem on a customer's truck and he had gone through all the same procedures.
I appreciate when a member posts their resolution as it helps others tremendously.
Old 05-15-2012, 11:14 AM
thunder92 thunder92 is offline
Vehicle: 2000 ram sport 360 v8
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
thunder92 is on a distinguished road
yes, thanks for posting resolution. As all should, its helps us all stay on the road.
