Old 05-06-2012, 01:25 PM
Ace--'s Avatar
Ace-- Ace-- is offline
Vehicle: 2012 Ram 1500
Trim Level: LoneStar
Rep:55
Ace-- will become famous soon enough
Default 7" CST Lift 2wd Help please
Sorry for what may seem to be a noob question, but I will be putting on soon I am curious of Gears, Im unsure what gears I have now but do I have to get the gears changed? If so what recommendations?
Old 05-06-2012, 03:52 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
You don't have to get theM changed, but I would. DePending on the tire size you're moving up to. It will make a 5mpg difference and HUGE power difference. As for brands, I would use Yukon. Thing is no one makes any gears or carriers for us yet. However I can get your carrier modified to fit the older style gear's bolt pattern. Just let me know if thats somethin you would be interested in.
To check your current setup, did you buy it new? If their was no mentioning on the sticker, more than likely you have 3.55s. But to be sure, crawl under you driver side axle and there will be a tag with your ratio
[CENTER][SIGPIC][/SIGPIC]
Old 05-06-2012, 04:03 PM
Ace--'s Avatar
Rep:55
Sweet thank you! I intend on doing it as I've been reading im looking into a 4.10 I am at 3.55 right now just bought it a week ago. I am just trying to see if it a MUST do now cause im hearing its a tad pricey. And ill be running 35X12.50X20 tires
Old 05-06-2012, 04:07 PM
candy08's Avatar
Rep:213
I would personally do it when you lift it. What size tires you going to run?
Its not pricey if all you're doing is a gear swap. Especially if you're only 2wd
Old 05-06-2012, 04:10 PM
candy08's Avatar
Rep:213
Damn you edited haha. What 35s are you gonna run?
You'll have a new gear ratio of about the factory 3.21 and all the additional weight. Depending on the brand will depend on how bad you kill your power!
Old 05-06-2012, 04:12 PM
Ace--'s Avatar
Rep:55
Haha, my bad I ordered these tires called Durun Trail Grabbers my friend has them and loves them. I really want to do it same day i get lift but if its not within price reach I may have to collect my pennies.
Old 05-11-2012, 06:10 AM
trojanman22 trojanman22 is offline
Vehicle: 2010 Ram 2500 Laramie Megacab
Engine: 2010-2012 409ci (6.7L) Cummins Turbo Diesel 305hp 610lb/ft (Chassis Cab)
Rep:13
trojanman22 is on a distinguished road
How much did u pay for your kit and where did u get it? I have a 2012 ram 1500 2WD
Old 05-11-2012, 10:50 AM
Ace--'s Avatar
Rep:55
Around 1500 with front and rear shocks from performancelifts.com
Old 05-12-2012, 10:55 AM
marshallsmith44 marshallsmith44 is offline
Vehicle: 2007 dodge ram 1500
Rep:74
marshallsmith44 will become famous soon enough
i have the cst 7'' kit on my truck and love it, good quality lift
