Old 08-01-2012, 10:03 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
DB-all with the T-harness is a remote start for the truck.
here watch this Fast
Real cool, and only about 80$
This was awesome, and a great tutorial. I really need to put one on mine. If you can tell me what to buy and have it come pre-programmed. I really like the plug and play. I have a 2007 Quad SLT. Mine is a bit different since the ignition switch is on the column.
Old 08-01-2012, 10:17 AM
Asur Asur is offline
Vehicle: .
Rep:4373
there are 2 parts to my kit,
First part is the DB-All,
go here to see the products and check compatibility with your truck
http://www.xpresskit.com/default.aspx
as for the T-harness, that is an harness made for the 09-12 ram's, but if you do a search on there site, it lists all you need to do the by-pass.
and you can see the wire harness bypass cable, then its just finding a place to get the stuff from,
I picked it up off ebay and the guy who sold it to me pre-programmed the db-all to fit my truck. Same with the T-harness, picked it up off ebay
Old 08-01-2012, 10:44 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Yea $80 vs $400 is a no brainer
sales@revelperformance.com
Old 08-01-2012, 05:16 PM
Vehicle: N/A
Rep:1045
yea mine had a compustar security system in it, so I love starting it from a distance n watching people jump cause of the straight pipes. ill never buy one of those though ... it's pricey
Old 08-01-2012, 05:50 PM
Revel Performance
Rep:1804
Yup, had one in a previous car(s) and moved it from vehicle to vehicle as it costed me $650 installed.
But it did have 3000 ft range and the pager showed me when it started, doors were open, etc
Old 08-01-2012, 05:56 PM
Vehicle: N/A
Rep:1045
yep it does all that. the remote even vibrates and goes nuts when the alarm.goes off.
we have a bratty pack of children in the neighborhood, and they snapped one of my CB antennas off. Angry, but I retaliated by waiting. a few days later that were 'playing' hide and go seek.... by my truck. full security mind you, so it screeches, wails, siren, beeps etc.... and I'm watching em in the window scatter faster than fastNugly.
one of the little suckers had the nerve to come to the house later. my wife gave him an earful. he looked like he'd seen a ghost. she makes me proud.
so I love my setup ... alarm, and remote start
Old 08-01-2012, 05:58 PM
Revel Performance
Rep:1804
Sounds like what I had....left it in the last vehicle as it was getting old.
Old 08-05-2012, 11:48 AM
Vehicle: .
Rep:4373
Well finally got my Switch's in, installed one for my Fog lights, there pretty nice, not sure how long they will last. Also got my EDGE CTS in, gives me alot of info on the engine like the EVIC "which I don't have on my Dash" so kinda usefull, + a whole lot of other info, and I can use it to change the mapping of my ECU when every a tuner comes out, also gives me all the engine codes and allows me to reset them. I velco'ed it to the dash for now, does not get in the way of anything else where I put it.
Old 08-05-2012, 12:58 PM
Revel Performance
Rep:1804
Great installs!
What did that Edge CTS cost you?
What will it give me on top of what my EVIC tells me?
I have to install my switches someday soon
Was it difficult to get it into that spot where yours is at?
Old 08-05-2012, 01:07 PM
Vehicle: .
Rep:4373
For the switch, no issues, nothing behind it at that location. I think the Edge CTS will only give you anything more but engine codes and the possibility to reset your maintenance stuff, it gives alot of other stuff you probably would never use like ABS pressure, spark timing. Engine load, intake temperature from your CAI sensor, I mean nothing you can do without, but for me, it gives me everything from the EVIC + all that other stuff, so worth it for me. I cost me 285$. When a Tuner comes out, I can then set up 4 mappings in it. It can also take eternal camera [i.e. like a backup cam].
here more info
Mine is just the Monitor CTS, not the programmer since our ecu is encrypted, but later I can setup power modes in it. If your truck is diesel, it has even more options in it
