Old 06-20-2013, 09:20 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Looks good. That can is definitely better than the old one.
Just FYI, there is one that will bolt up to the 4.7L as a "kit". It's the same moroso one but is specifically marketed for the hemi rams(4th gens). It also fits the 4.7L though(it bolts to the radiator support). Once it came out I abandoned the catch can brackets we had been working on for the 4.7L's, as the moroso is a good can.
Sean
Old 06-20-2013, 09:24 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Do you know the Kit number from Moroso, I check and did not see it, I am sure Brandon would love to know this number. Thanks Sean, reps as soon as the site lets me
Old 06-20-2013, 09:36 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
It should be 85472
That's the Hemi specific one
sales@revelperformance.com
Old 06-20-2013, 09:55 AM
Vehicle: .
Rep:4373
It should be 85472
Hmmmm, 3/8 is a bit tight for the PVC valve, but ya it might work, but to not brake the PVC valve and hard plastic tubing I would pull the unit off and set it up off the engine, then re-install it, 36" might be a bit tight in tubing, wonder if you can order the 85472 with more tubing like 48", this would give you more room to install it towards the front like I did mine, the PVC valve is up again the firewall on the 4.7, right next to the Brake Booster behind the intake. This was the reason I used the 85486, it came with 54" of 1/2" tubing, had just the right amount to do what I wanted. Also the 1/2" tubing is snug on the PVC valve and the tube to the intake, a couple of collars make it snug and tight on them. Was my best solution, easy access in that area also. Worked for me, but since there is no specific kit for the 4.7 4th gen I would do the research to make sure you get what you need when ordering.
Thanks Andrew for the part number
Old 06-20-2013, 11:26 AM
snrusnak's Avatar
Rep:1388
Yeah my intent was get that can and bracket, and buy your own hose.
Sean
Old 06-20-2013, 06:07 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
No problem, when you decide to install the catch can, I can get you more pics oh where to link up and any info you might need
Thanks Asur! I'll let you know when I plan to do the mod
It should be 85472
Andrew, can you PM me a price for that catch can shipped to 98295? Thanks.
That definitely sounds easy enough. Hose is cheap enough to get at a local part store... it's the catch can and bracket I would be worried about.
Old 06-20-2013, 11:32 PM
Revel Performance
Rep:1804
PM sent
Old 06-23-2013, 01:10 PM
Vehicle: .
Rep:4373
Well here is another take on the Rear Seat Back Rest Fold down Mod. I had been wanting to do this for a while, one of the main reasons was to have a place to set things that i did not want carried on the Rear Seat and also an easy access to the rear window for cleaning of the glass. Well here is what I did.
Took a piece of hard condensed plastic (not sure how you call this type of plastic) and cut 2 pieces, 3/4" x 13" x 2.5" and drilled holes into it, 2 for the bolt area and one for the alignment pin of the seat.
Did the same for each piece and then cut a steel pipe to make support spacers to give the seat more solidity in case of impact.
unbolted the seat and installed the new spacers.
A little anti-seize done not hurt and the rear bolts must be be getting some sort of humidity as they were starting to rust.
Now for the Back seat rest the 2 clips that clip the pins on the back of the cab, the point of this clip unit has to be grinded down about 3/16th I noticed that the cab clips are not even. one is actually angled a bit higher than the other, the reason I did it this way is that if you put a 1" piece on the floor you loose the amount of bolt holding the seat, at 3/4" there is enough bolt to safely keep that rear seat attached. The 3/16th I removed makes it that the clips don't hit the hooks when pulling forward or putting the seat back to its location.
Here is with the seat up
And with it down.
Also, way more easy to clean the rear window now.
If you have questions let me know.
Old 06-23-2013, 07:34 PM
Revel Performance
Rep:1804
I will have some questions when I get to this after your other 5-10 mods on my list
Old 06-23-2013, 08:13 PM
Vehicle: .
Rep:4373
Anytime lmao, after those other 5-10 should be another 5 more lmao, t/c Andrew
