Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2012 Dodge Ram Forum
Old 05-06-2012, 11:00 PM
Timw7419's Avatar
Timw7419 Timw7419 is offline
Vehicle: 2012 Ram Sport Crew Cab
Timw7419 is on a distinguished road
Default Help - Pulsating vibration when towing a trailer
I hope someone can help me - This weekend I pulled a 2 place snowmobile trailer with 2 ATV's on it. When I got up to 55-60mph, a strange vibration started, and continued as long as I was above that speed. It can best be described as if I merged into the rumble strips, and back off, back on, and back off. It would pulsate from nothing, to very noticible, and was happening in cycles of about 5.5 seconds. Yes, I timed it! it did not change if I was in tow mode, or not, and it happened upon accelaration, and decelaration. I down shifted from 5th, to 4th, to 3rd gear, and no change. I shifted in neutral, and it did not change. The vibration could be felt in the steering wheel, the passanger seat, and you could even feel it in the dash. The trailer is new. I shifted the weight on the trailer for more, and less tongue weight, and it did not change. When I got home, I even took one of the ATV's off, and tried again - no change.
My truck has 7500 miles, Hemi 5.7, tow package, and 3.91 gears. I know it could be the trailer, but the "pulsating" has me baffled. I would think that if the tires were out of balance, it would be a consistant vibration, not a pulsating one. Any help, or suggestions would be appreciated.
Old 05-07-2012, 07:48 AM
2012Longhorn 2012Longhorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Longhorn ~V~
Rep:31
2012Longhorn is on a distinguished road
I get something similar when I tow my utility trailer. One of the tires either has a flat spot or it's out of balance (sat in the dirt for a year). When I tow my travel trailer, I have no problems (sat in concrete and tires covered).
Old 05-07-2012, 12:19 PM
KJ48 KJ48 is offline
Vehicle: 2014 1500 Ram QC
Color: Blue Streak pearl
Rep:122
KJ48 will become famous soon enoughKJ48 will become famous soon enough
If it doesnt do it without the trailer then have the trailer tires checked and balanced. Most trailer tires are never balanced new and as stated above the tires can flat spot if sitting a while.
Its also possible to just have a bad trailer tire, new or not.
Old 05-07-2012, 12:59 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Had this issue once before with my trailer, and it was both tires that were unbalanced and out of whack, and the vibration would go from almost nothing to very much. I actually replaced both tires and had the wheels balanced, solved my problem, How did i know it was not my truck, I had a buddy take my trailer for a test run and it did it on his truck.
Old 05-07-2012, 01:11 PM
IH Scout Driver IH Scout Driver is offline
Vehicle: 2012 Ram 3500 Crew Cab
Rep:42
IH Scout Driver is on a distinguished road
Most likely, it's the trailer tires (as stated above). I had my dual axle car hauler doing something similar and found that I had two low tires.
Also check your bearings on the trailer as you could have a bad spot on one of the bearings that is only noticeable at highway speeds. If you haven't repacked your bearings in a year or two, now is the time to do it. I personally despise bearing buddies as they'll destroy the seals over time.
Timw7419's Avatar
Thanks guys - I called the trailer dealer today and am taking it back Wednesday for them to check. I'm glad to hear someone else saw the same thing - I thought I was going crazy! I'll post back if that fixes the problem.
Old 05-07-2012, 06:44 PM
Timw7419's Avatar
Took off early and took the trailer in today - they swapped out the 8" tires for a set of 10" tires and the problem went away almost entirely. I'm going to try and get them balanced and see if the problem goes away completely. Thanks for the help!
Old 05-22-2012, 10:08 PM
qwikgto's Avatar
qwikgto qwikgto is offline
Vehicle: 2012 dodge ram
Trim Level: big horn
Color: Deep Cherry Red
qwikgto is on a distinguished road
wow i just had the same issue towing my dual axle trailer.
Old 05-23-2012, 06:30 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
This can also be caused by a trailer axle taht is out of alignment. It is really noticeable with smaller tires as the trailer gets yanked to one side and them pulsates until it gets back to centre line and then starts yanking itself over again, but most likely wheel balance.
Old 04-13-2013, 09:14 PM
OxyG3nE's Avatar
OxyG3nE OxyG3nE is offline
Vehicle: 2012 Dodge Ram SLT
Color: Dark Blue
OxyG3nE is on a distinguished road
i had the exast same problem ... today !! ill have ti balance!!
trailer pulsating towing
