Old 05-06-2012, 11:34 PM
08ramtrx4 08ramtrx4 is offline
Vehicle: 2008 dodge ram 1500
Trim Level: TRX4
Color: Elec Blue
08ramtrx4 is on a distinguished road
Default over drive when do ya'll take the truck out of o/d
In town i take it out of o/d..But when i get up past 45 i put it back in..Seems like the truck drives different in town with it on and seems like the mds kicks in more.we parts tru town that is 45mph.
Old 05-06-2012, 11:39 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
You're going to want to keep it in O/D in town, keeps those RPM's down thus keeping up the MPG's. You generally should read the owners manuals to get the answers which is why they print them and include it with the truck, I wonder how many people buy a vehicle and total it and never read the damn manual! Anyway's take it out of O/D when you tow, if the truck seems unstable in O/D (keeps shifting in and out of O/D), if you're going up a steep hill for extended periods of time. One issue with driving out of O/D is risk heating up the engine much faster and sometimes if you drive with O/D off for an extended period of time you could risk overheating the engine. Anyway's just keep it in O/D except when you tow.
Old 05-07-2012, 08:19 PM
Trim Level: TRX4
Color: Elec Blue
The mds makes the ram drive different then most cars that have od
Old 05-07-2012, 09:31 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I'd leave it in OD unless the trans is "hunting" back and forth for the right gear. If that starts to happen just hit the tow/haul button and you should be fine. If you end up in the Rockies or some place where the inclines/declines are steep then you may want to manually select your gear.
Old 05-07-2012, 09:47 PM
MoparMadness08's Avatar
MoparMadness08 MoparMadness08 is offline
Vehicle: 2008 Dodge Ram
Color: Cool Vanilla
Rep:63
MoparMadness08 will become famous soon enough
It wont hurt to take it out of O/D in town. I do all the time. I cant stand it shifting all the time and the mds kicking in and out. its annoying.
DSP 91 Oct Tune, BFI Intake, 14" Magnaflow, 180 Stat, Lund Genesis Tonneau cover, Recon LED light bar, Rocky Mtn ATS 305/55/20,
Old 05-07-2012, 09:57 PM
CHVYKLR's Avatar
Rep:252
I hated the MDS kicking in and out too that's why I turned it off. I really tried to put up with it and couldn't.
Old 05-07-2012, 10:01 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
I don't take it out. I just drive faster if it's hunting for gears. Problem solved
"I don't care to hear what your ideas are, mine are better"
Old 05-08-2012, 03:07 AM
Trim Level: TRX4
Color: Elec Blue
ya mds drives me nut diff with the flowmaster dumped gonna change that soon just dunno what..kinda want to go single back stock but just a bigger tip like 4 inch tip.
Old 05-08-2012, 11:01 AM
RAMROD5's Avatar
RAMROD5 RAMROD5 is offline
Vehicle: 2006 Dodge Ram 3500 Dually
Rep:13
RAMROD5 is on a distinguished road
im always in overdrive, unless im hauling something that has some weight to it, then i use tow haul mode, if im decending down a mountain ill take it out of overdrive mode, sometimes even put it in 2nd for the engine braking. up steep mountains ill drop it out of overdrive also if im empty.
2006 Ram 3500 Dually, 5.7 hemi.
Old 05-08-2012, 11:19 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Hello 08ram and I too take it out of O/D and run around town in 4th when speeds go no higher than 45mph. I get no higher than 1800rpms at 40-45 when running town errands which is an ideal range for me. I still do good with gas mileage (16.5mpg)doing this. Even with outside temps of 95' and humidity @ 100%, my coolant temps are still holding at 190-200 degrees according to the EVIC and just below half on my needle temp gauge. But to each his own. I just don't like luggin my motor around town.
