Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 05-07-2012, 09:37 PM
dscott27 dscott27 is offline
Vehicle: 2000 dodge ram 1500
Trim Level: LS
dscott27 is on a distinguished road
Unhappy Battery not charging
Having intermittent problem with my 2000 1500 5.9 4wd. Battery keeps failing to charge. I replaced battery and over 1 month period of limited use, battery was dead. Jump started truck, and after few minutes seemed to charge battery and was able to shut off truck and restart without a jump. Drove truck for about 1 hour with a couple of stops and seems to be charging battery. Drove some more and check engine soon light turned on and battery meter was pegged all the way to the right. Stopped at gas station and shut off engine and battery was completely dead.
Took alternator to Autozone and they said it tested good, lamp/diode, regulator, rectifier all passed. Put alterntor back in and charged battery and is currenty running, but not sure how long it will last. Is there a separate voltage regulator that can be tested/replaced? Any suggestions on what is causing battery to not recharge?
Any suggestions would be appreciated.
Thanks,
Doug
Old 05-08-2012, 08:00 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
The computer also regulates charge. If I remember right thers a way to bypass it p.m. warlock I think he's done it.
