Old 05-09-2012, 08:38 AM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Question Weird Sound (Ting Ting, Ting Ting) No Idea at all..
Well this has just started to happen the past few weeks, and not all the time.
I think it has happened maybe 3 times the past 2 weeks. When I get into a drive threw I start hearing a loud (ting,ting,ting) sound.
The walls probably echo the sound to make it easier to hear, who knows it could be happening when Im driving too??
Dad says it could be my belt, because it has happened to him before, but it sounds more of a piece of tin clanging on something. Going under the light today to see if anything looks out of place on her.
Going to TRY to get the noise to come back, which never works when you want it too.
Anyone have any idea, cause I am blank?
Old 05-09-2012, 08:51 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Check exhaust connections? That would be my first guess. Or anything hanging by any moving parts?
I hate problems like this. GL and let us know how it turns out man!
2011 Big Horn 4x4 -SnowWhite-
Old 05-09-2012, 09:05 AM
Bordin's Avatar
Rep:516
I know its a piss off, because it only happens when it wants too. And its kind of embarrassing at the drive threw when you need to speak louder to order your damn coffee cause of it.
But will do man, last day off than back at it for 7. So its the only time now
Old 05-09-2012, 09:09 AM
SS4Luck's Avatar
Rep:310
Start it and check it, then let it get warm and check it again. Ive had noise problems like this where it took heat to make shit loud enough to hear
Old 05-09-2012, 09:34 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
That's weird man, I havent noticed that...yet.
However for a week now I am getting a super sweet metal on metal grinding noise when I first crank it up in the morning. Its only on that cold start of the day, so I know the dealer won't be able to replicate it. Guess we have to wait these things out till they blow
[CENTER][SIGPIC][/SIGPIC]
Old 05-09-2012, 09:45 AM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2015 Dodge Ram
Rep:166
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
I had this same problem on my 2011 Ram Hemi and the dealer replaced my cats under warranty because they were breaking apart inside and causing the sound
Old 05-09-2012, 09:50 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
If it only does this in gear, does it do this in both drive and reverse?
I'm just wondering if this is driveshaft related. Internal separation or U-joints. :4-donknow:
Does it sound like it's from under the truck or under the hood?
brad
Interested in one of my mods?
Old 05-09-2012, 10:12 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
could it be the check valve (don't know what else to call it... it's supposed to keep exhaust gasses from back flowing) on the exhaust/ exhaust manifold?
Doe it do it only at idle, or while under load as well?
Exco
Bill
Old 05-09-2012, 10:25 AM
SS4Luck's Avatar
Rep:310
^^ Do you know where this check valve is located? I never saw anything valve like in my exhaust when we took it off and the only OEM exhaust piece I have is my I pipe..
EDIT: Are you talking about the EGR valve that comes on some cars? Our Hemis dont have that
Old 05-09-2012, 01:49 PM
Jody79 Jody79 is offline
Vehicle: 2011 ram 1500
Trim Level: express
Color: blue
Jody79 is on a distinguished road
I have been experiencing the same noise through the drive through. I also have a very loud knocking noise at initial startup in the morning and then after work when I start it to go home. Any ideas????
