Old 05-08-2012, 03:20 PM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
Default Gear Swap on 2010 Failure
Well,
Just got off the phone with my mechanic that was doing the gear swap on my 2010 Dodge Ram ST Quad Cab 4X4, and the gears that everyone said would work fine from Motive Gear; do not fit. When the backlash is set proper he said the the gear rubs the case. Release enough to relieve the rub and you got .030 plus and slap.
This is of course the second attempt after he realized that a special tool is required to release the preload. Guess I just ate $600 in parts and $400 in labor. Beautiful!!
Is there any information about these POS rear ends listed on any sights?
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 05-08-2012, 03:57 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Run some quality gears. Its deinately not the "pos"rearend. First I've heard of a bad install in a 02-10 9.25 rearend. Its either your gears or your mechanic. I have gears for your rearend installed on the ZF rearend. Now that's a motivated installer
[CENTER][SIGPIC][/SIGPIC]
Old 05-08-2012, 04:18 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^I agree 100%. This is the first issue I've heard.
Sean
Old 05-08-2012, 04:47 PM
Rep:2657
2011 & '12 Ram rear differentials are ZF designed, same rear end was in 2010 & Newer Grand Cherokee & Dodge Durango
Yours being a 2010 has to be the older style
Randy's Ring & Pinion website info
Chrysler 9.25" Rear, '01-'09
Chrysler 9.25" Rear, '01 & newer
Ring Gear Diameter: 9.250
Cover Bolts: 12
Ring Gear Bolts: 12
Spline Count: 31
Dropout: False
Pinion Support: False
Carrier Breaks: none
Rear Suspension: Solid
Pinion Nut Size: 1-5/16
Compatible with Models:
Dakota: 2001 - 2009 (Rear)
Durango: 2001 - 2009 (Rear)
Ram 1500 1/2 Ton: 2001 - 2010 (Rear)
Ram Van 1500 1/2 Ton: 2001 - 2003 (Rear)
Ram Van 2500 3/4 Ton: 2001 - 2003 (Rear)
http://www.ringpinion.com/b2c/PartCa...4WD&DiffID=111
One of this sites sponsors are Yukon Gear
Old 05-09-2012, 01:28 AM
Rep:27
The POS wasn't standing for "Positive" LOL. Called a shop and taking it in to them on Monday they talked with another source and have a different brand to install.
Could by my mechanic I suppose, but fI"m doubtful. He has done quite a few gear swaps and he actually machined the special tool required to relieve the pinion bearing load. Guess I will find out on monday when I take it to a local shop and see how that turns out.
Anyone interested in a set of 9.25 Motive Gears in 4.10
Old 05-09-2012, 01:40 AM
Rep:27
Yea, also tried to get the Yukon Gears and they told me that they are on back order about two months, so went with another brand.
