Where is the V6 "Love" - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
Old 05-08-2012, 03:22 PM
samsquanch samsquanch is offline
Rep:27
samsquanch is on a distinguished road
Default Where is the V6 "Love"
I know I can't be the only one around here. I know its not the biggest or fastest out there, but there must be others running the 3.7 V6 that are satisfied with their choice. Sure we chose it for financial reasons, for the most part, but that doesn't mean we can't have a little fun with it in the mean time. My time with my V6 is just starting and I would like to try and find a little inspiration.
Rob
Old 05-08-2012, 09:55 PM
chambers chambers is offline
Vehicle: 2004 Dodge Ram 1500
Rep:29
chambers is on a distinguished road
I've done every bolt on worth it on the v6 and dyno'd it. I would really like to see someone do before and after dyno runs w/ custom cams and a tune. I want to see what kind of power can be made from it, I think some guy w/ a dakota did cams but I don't think he ever got them dyno'd and has disappeared from the forum I found the info on.
Old 05-08-2012, 10:54 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
^JW what'd you dyno at?
Sean
Old 05-09-2012, 12:08 AM
Rep:29
182 hp, though it probably would have been higher but I ran it in 4th thinking the speed limiter was off and it wasn't, so it drops off just past 5k rpm where it hits the limiter. Torque was good and flat from 1500rpm up w/ peak of 210 ft-lbs. The dyno's are in this thread http://www.ramforumz.com/showthread.php?t=64326 w/ details.
Old 05-09-2012, 08:06 AM
snrusnak's Avatar
Rep:1388
That's not bad man. You're making about the same torque as the new 4.7L. Nice to see a hopped up v6.
Sean
Old 05-09-2012, 01:26 PM
Rep:29
Haha, no not really the new 4.7 is what 330 ft-lbs, and my truck puts 210 to the wheels. My hp is about what a stock older 4.7 puts to the ground though.
Old 05-09-2012, 01:31 PM
snrusnak's Avatar
Rep:1388
No you are right about at the same as the 4.7L.....that's 330 lbft at the crank, not the wheel. A 2008+ stock 4.7L is about 200 lbft at the wheel, give or take.
http://ramforumz.com/showthread.php?t=109335
You lose less power through a manual gearbox than the 4.7L does through the auto, that's a benefit.
I'm excluding peaks, and just going off the main flat line "curve".
Sean
Old 05-09-2012, 03:43 PM
Rep:29
Wow, didn't think they were that low, I think the old 4.7's put out better torque but had less hp. Anyone on the forum run their trucks to compare to SC numbers?
Old 05-09-2012, 03:48 PM
snrusnak's Avatar
Rep:1388
The older regular 4.7L was 235 hp 295 lbft. The newer 4.7L is 310 hp 330 lbft. Not sure what the older HO 4.7L was rated at, but it is less than the new 4.7L for sure.
The new hemi's usually dyno ~300hp peak. They are rated at 390hp at the crank.
I've seen a few 2008+ 4.7L dyno's and they are pretty consistent. With the tuner it really helps out.
So did you ever do cams?
Sean
Old 05-09-2012, 03:52 PM
Rep:29
No, figured it wasn't gonna be worth the headache since I was gonna put them in myself. Doing a cam on the older hemi and 4.7 always gave good numbers, so I wondered what the 3.7 could do w/ one. I don't have any dyno's on hand but I want to say the older 4.7 put out better torque to the wheel than the new one's in stock form, just from seeing the graphs you linked to.
