Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
tonneaucovered.com
Old 05-09-2012, 03:58 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I don't have any dyno's on hand but I want to say the older 4.7 put out better torque to the wheel than the new one's in stock form, just from seeing the graphs you linked to.
Maybe with a cam...? Definitely not stock.
Old 4.7L 295 lb ft peak
New 4.7L 330 lb ft peak
Same exact drivetrain(transmission and rear axle) so no way there was a difference to the wheel. Unless it was manual trans.
Not to knock the old 4.7L, it's a good truck engine, but the new 4.7L is significantly improved upon. My dad has a single cab 2005 4.7L "work truck" and it runs fine but it's pretty slow. I have my 2010 4.7L quad cab with much larger and heavier wheels/tires and it is ....let's say....quick. I wouldn't say it's fast, but it's fun and "peppy".
I wish someone would make cams for the new 4.7L, and long tubes. You'd see some 400+ hp 4.7L's if it ever happened. That's a lot of power from a 287 NA.
Anyway, this is about the v6 lol. So do you have any other plans or just going to be satisfied with it as is?
Sean
Old 05-09-2012, 04:01 PM
chambers chambers is offline
Vehicle: 2004 Dodge Ram 1500
Rep:29
chambers is on a distinguished road
Haha, no, I'm leaving it alone. I've been trying to figure out why my mpg dropped off, that's all I'm worried about now. I've got a bike now for going fast, seems you do as well.
Old 05-09-2012, 04:05 PM
snrusnak's Avatar
Rep:1385
Yeah. I've been modding my bike a lot lately, and it keeps making me realize how much easier and cheaper it is to make a bike go fast than a 5,000 lb truck...
I'm on the verge of 100 hp / 100 lbft for the bike. Should happen within about a year. That'll satisfy my speed cravings lol. As for the truck, I'd just like to get the exhaust(including headers) and a few other things done and I'll be satisfied with it. I can't complain, I get nearly 20mpg avg with a big heavy 4 door v8 truck that has decent acceleration.
Sean
Old 05-09-2012, 04:11 PM
Rep:29
Yeah, that is what I used to get for mpg, now at like 15-16 all the time. I'll figure it out or die trying.
OP let me know if you have any questions about mods, I posted a thread on here w/ the mods for the v6 and info http://www.ramforumz.com/showthread.php?t=91685.
Old 05-09-2012, 08:39 PM
samsquanch samsquanch is offline
Rep:27
samsquanch is on a distinguished road
Finally a little discussion lol. 4.7 throttle body, will it fit the 3.7 with a little modding? I am out of luck as far as tuners go, for now at least. Mine is a 2012 so the ecu is locked up tighter than (insert simile here). I'm not looking to make a gazzallion HP, just want to wake it up a bit, intake, exhaust, throttle body etc. Gonna be more of a cruiser and light towing vehicle, not a drag racer. Not saying it wont ever go down the track either, that is a blast whether you are fast or slow.
Old 05-09-2012, 08:58 PM
snrusnak's Avatar
Rep:1385
Can you post a picture of the stock TB? I doubt the 4.7L TB will fit or be a good mod as it's pretty large. The older 4.7L maybe, as it is smaller.
Fastman is probably the best bang/buck for TB mods. Google "fastman throttle body".
Sean
Old 05-10-2012, 12:11 PM
Rep:27
Is there much point in changing the throttle body without a tuner available?
Old 05-10-2012, 12:27 PM
snrusnak's Avatar
Rep:1385
It would still help. It won't be huge but if you did a lot just like chambers then you would gain a good bit. If you just do a TB, CAI and call it quits it'll hardly make a difference. If you do TB, CAI, headers, y pipe, muffler, underdrive pulley, etc. then it'll be a good difference. In all reality, it's not worth the money(but either is it on the 4.7L or 5.7L so that's up to you...).
Sean
Old 05-11-2012, 02:35 AM
Rep:29
The fastman TB similar to a CAI will give you better throttle response, something you can feel. How much HP I don't know, you could try a jet chip until an actual tuner comes out. Even w/ all my mods the stage one still made a small difference in the higher rpms. I can't speak for the stage 2, w/o a tune the headers aren't worth it IMO, aftermarket muffler and y-pipe will give you something and be cheaper. The underdrive pulley was also something I could easily feel a difference in the truck after install.
Old 05-13-2012, 11:24 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Sean, I have to ask...are you high? There is no way you lose 100+ ft-lbs between the crank and the wheels... 50 is considered substantial powertrain loss.
US ARMY-RETIRED
2015 Ram 1500 Laramie Crew Cab 4x4. 50k Miles...LOADED...BF Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, TruXedo Roll-up Soft Tonneau, MaxMate Stainless Brush Guard, 10k Lumen 22" Solidex LED Bar, DZ Tailgate assist, Total Load Control, AVS Visors and Bug Shield, K&N Drop-In, XenonDepot 5000k HID Headlamps in projectors.
