2011 ram 1500 looking for advice on 4'' and 6'' lift kit - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-09-2012, 12:35 AM
mike24 mike24 is offline
Vehicle: 2013 ram 2500 big horn
Trim Level: big horn
mike24 is on a distinguished road
Default 2011 ram 1500 looking for advice on 4'' and 6'' lift kit
i'm looking for some advice/ opinions on 4'' and 6'' lift kits. just recently i put a sst 2.5'' readylift lift kit in my truck. it is a nice lift but im just not sitting tall enough. i was wondering if some one cane help guide me on a nice 4/6'' lift kit and how the ride quality is. obviously the qulity is going to be not as good as stock but do you start to run into things starting to break? i know superlift 4'' is so post to be good but idk about the 6'' and if there is a major difference in installation?
Old 05-10-2012, 10:57 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
There should be no difference really with installation between the 4 and the 6. As far as ride quality goes most members report that ride quality stays the same if not gets a little nicer with a good quality lift. I would bet its because of the upgrade in shocks usually associated with lifts.
Is there anything specifically your looking to raise the truck to use it for? Certain size tire you wanna run? Most guys have really good luck with the RCX lift kits
2011 Big Horn 4x4 -SnowWhite-
Old 05-14-2012, 09:20 AM
i was looking at the bds 6'' lift, it seems to be good quality and i see a lot of ppl using that lift. plus they have the rear fox fox and they r working wiht fox right now to come out wiht coilovers for the front.
