Old 05-09-2012, 01:18 PM
Cobra7077's Avatar
Cobra7077 Cobra7077 is offline
Vehicle: 2003 ram 1500 slt
Cobra7077 is on a distinguished road
Default Racing idle at startup
I have a 2002 Ram 1500 with the 4.7 When I start her up the idle revs to 2200 like I'm starting with throttle pushed down, Then she floats back to 1000 and jumps back to around 2000 back and forth...I have no cel and my obd2 scanner finds no engine or tranny faults... Anyone have an idea where I can start looking?
Old 05-09-2012, 01:39 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Check for vacuum leaks first. Then I'd start looking into sensors. Usually they throw codes, but not always. Throttle position sensor or Idle air control would be most likely to cause that. Idle air control may just be dirty and need cleaned.
Sean
Old 05-11-2012, 02:43 PM
RetiredJeeper's Avatar
RetiredJeeper RetiredJeeper is offline
Vehicle: 2005 Dodge Ram QC
Trim Level: SLT Quad Cab
Color: Blue
RetiredJeeper is on a distinguished road
same here but not as quite of a high rev. mine only does it after drivin a while whens it gets warm. vaccum leak normally revs high and stays there. im willin to bet its the idle air cobtrol valve although i have no codes either
Old 05-11-2012, 02:44 PM
snrusnak's Avatar
Rep:1385
More than likely IAC or TPS. But checking vacuum lines is free.
Sean
Old 05-16-2012, 12:38 PM
Cobra7077's Avatar
I changed the spark plugs... some moron had some bosch platinum3 plugs in there... Plugs had no tips left they were so worn out... I replaced with copper Champion/Mopar plugs... The Vac hose on the back or the intake box that connects to TB was disconnected so i hooked it up and she idles 1000 times better... Still surges a few hundre rpm during startup though.
