Old 05-09-2012, 02:26 PM
vincesram1500 vincesram1500 is offline
Vehicle: 2005 Ram 1500 4.7L
Color: Mineral gray metallic
vincesram1500 is on a distinguished road
Default Efan swap info and cooling question
I am interested in reading about the electric fan swap I've been seeing in some message titles, however I'm having trouble with the search. I'm unable to type text in the search bar. I'm using Internet on my phone cuz its blocked at my work. Anyway, I've noticed that the temp gauge on my truck points straight up to the half way mark once the truck is at operating temp. I honestly remember it staying just before this mark. I had a small pin leak in my radiator and after the new unit was in it stayed there. A new t-stat was also put in. So I'm wondering has anyone else had this issue and did you switch fans as result?
Old 05-09-2012, 02:45 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Your replacement tstat is probably opening at a slightly higher temperature than the original one. There is variance in the opening temperature, they don't all open perfectly at the exact temp stamped on the tstat. Also, you may have a small amount of air trapped in the cooling system that could cause it to run a little hotter.
Basically, the fan has nothing to do with what you're describing, the fan is working fine.
If you want to go to an electric fan, it'd be something aftermarket/custom. I think the threads you've been seeing are for 4th gen rams that are switching to the v6 efan that is bolt on and plug and play.
Sean
Old 05-09-2012, 03:10 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Talking Temp
My temp gauge reads right in the middle of the dial when warm. Perfectly normal.
Old 05-09-2012, 07:55 PM
icywhite's Avatar
icywhite icywhite is offline
Vehicle: 04 dodge ram
Rep:29
icywhite is on a distinguished road
yeah mine too reads almost stright up
2/4 drop,h.o. cams,4.56s posi, stage 2 cai, 70mm tb, 180t, cutouts, efan, centerforce dual friction clutch,short throw shifter 24%, sct(tuned by flying ryan), high flo-Y, 3 inch exaust , jbl headers, 2013 intake manifold, nitrous, killian ported heads,leds and hids on all lights,
Old 05-13-2012, 10:39 PM
Tony I's Avatar
Tony I Tony I is offline
Vehicle: 2003 dodge ram
Trim Level: SL
Tony I is on a distinguished road
I want to do e fans!
Old 07-25-2012, 01:19 PM
senseone senseone is offline
Vehicle: 2002 Dodge Ram
senseone is on a distinguished road
I'm just going to bump this thread up as oppose to making a whole new thread. But I am unable to find any good info or good solid write ups on doing this electric fan conversion. Does anyone have any good info or a site they used? I am looking into using the taurus fan as well.
Old 07-25-2012, 11:27 PM
HemiEd's Avatar
HemiEd HemiEd is offline
Vehicle: 2003 Ram SLT, 4wd swb
Rep:27
HemiEd is on a distinguished road
I am also interested in this mod, as I read it was one of the most beneficial ones you can do.
Old 07-29-2012, 12:39 PM
Nutshell's Avatar
Nutshell Nutshell is offline
Vehicle: 2011 Ram Crew Cab 4x4
Trim Level: Bighorn
Color: Metallic Grey
Nutshell is on a distinguished road
I have the Taurus fan mod done. Works well, fits well...one issue is big amp draw. I will be switching to Flex a Lite 183 soon.
Amsoil EAA filter, 87MM TB, 192 thermostat, E Fan, Magnaflow 22 & Y pipe, BT Catch Can, Diablo Intune.
Old 07-30-2012, 10:21 AM
HemiEd's Avatar
Rep:27
Does it have less current draw? Does the 183 come complete with the temp sensor, relay, switch etc? I noticed that Amazon has by far the lowest price on them that I have found, but I am not sure they are complete.
Old 08-04-2012, 01:20 PM
Nutshell's Avatar
Trim Level: Bighorn
I t does draw less. I saw the 183 on Amazon, crazy lower price than anyone around...makes me wonder.
