Old 05-10-2012, 08:59 AM
act3am act3am is offline
Vehicle: 2002 4.7L DODGE RAM
Color: BLACK
act3am is on a distinguished road
Default Lost coolant oil is milky DESPERATELY NEED HELP
Wats up RamForumZ member I desperately need help. 2days ago i was driving on the highway and the oil pressure gauge dropped and stalled on me. I got it towed home and check for engine codes, and the P0112 code came up which is Air Intake Temperature Sensor circuit Low. I took the sensor out and it was melted so I replaced the sensor check engine light is gone. Then i looked up under the car and there was engine oil on the tranny. I checked the oil on the dipstick and it was milky. I pulled the spark plugs and there were no oil or coolant on them. I tried to start the car again and it will start up rough and then shut off. Over night all the coolant leaked out on the floor. Anyone else have this problem?
P.S. - There were no overheating issues before this happened
Im stuck.
I dont know whether its the Headgasket or Intake Manifold Gasket or sumthin else.
Thanks In Advance
Old 05-10-2012, 10:04 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Headgasket is my opinion..
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 05-10-2012, 10:13 AM
OhioRambler's Avatar
OhioRambler OhioRambler is offline
Vehicle: 2002 Dodge Ram 1500
Color: Mineral gray
OhioRambler is on a distinguished road
I am guessing Head gasket too. Had that happen to mine.
Old 05-10-2012, 10:36 AM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
Engine Rebuilt Time
Old 05-10-2012, 10:55 AM
Color: BLACK
Same exact thing happened... But if it was the headgasket would I still be able to start and drive?
Old 05-10-2012, 12:44 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Sounds logical that it's the head gasket. I'd talk with superiorstyles if possible, he's very knowledgeable on this engine.
Sean
Old 05-11-2012, 08:31 AM
Color: BLACK
ok cool thanks alot
Old 05-11-2012, 04:21 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Red face Your head
I agree with the guys. It's probably a blown head gasket, or a cracked head. What worries me though , is the coolant and oil on the GROUND. Even if you had a blown gasket, it wouldn't leak externally. You may want to get under the truck with some cleaner and a strong light and have a look around. Good luck.
Old 05-11-2012, 04:39 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
What about a freeze plug they still put them on newer engines
Old 05-11-2012, 06:02 PM
Rep:2620
I agree on cleaning off the top & bottom of the whole engine & engine compartment
It can't hurt & it is like hand washing your vehicle, you see every little thing
You should do the standard compression , leak down test, radiator pressure checks
If you pull the intake & head(s), go one step further & check the plenum gasket
Hughes is suppose to make a good one
