Tow mirrors - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 06-21-2012, 01:47 AM
holydiver89 holydiver89 is offline
Vehicle: 2012 Dodge Ram 5.7 HEMI QC
Color: Brilliant Bright White
holydiver89 is on a distinguished road
Does anybody with the tow mirrors that have puddle and blinkers know the part # for your door module? I have a '12 ST that has no lights on it but want to upgrade to those mirrors
Old 06-21-2012, 10:54 AM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
Don't know the part number, but priced out the door module and harness required at the stealership and it was $289/side. There is a thread on here somehwere that has how to tap the dome light and blinker circuits and will cost you about $20 in wire and parts. I'd recommend that method.
Old 06-21-2012, 11:35 AM
I don't have dome lights either that's the next mod
Old 06-21-2012, 11:43 AM
From what i've been reading, the mirrors plug directly into the door modules (i'm going outside now to confirm) and my ST would be missing 2 pins on the module but I THINK part #04602911AJ and 04602910AJ are the right ones and are only $40 each at factorychryslerparts.com. The item description is as fallows: (MODULE. Door. [GP1] Or [GP2] Right. . "Power Folding Black Trl Tow Mirrors"="Power Folding Chrome Trl Tow Mirrors"+"Door Parts Module"%"Pwr Front Windows, 1-Touch,Up & Down"%"Pwr Windows, Front 1-Touch Down". Required: 001). I don't know if this includes puddle lights and blinkers or not though i'll have to count the pins, I'm guessing I only have 2 right now (heat and power) maybe a ground so 4-5 pins for the tow mirrors
Old 06-21-2012, 04:15 PM
Rep:14
You'll also need the complete wiring harness for the door on each side as the signal wires to the module from the TIPM are not there either.
On top of that you'll need to flash the truck which is generally charged at $100 by most dealers unless you have a buddy who works there.
Old 06-21-2012, 05:47 PM
Good to know, thanks. So in theory if I have both new modules and harnesses it will work. I called the dealer about some other codes and they said if the sales code isn't listed under my vin, they can't add it, don't know if that's true or not. I have what I believe is the codes for mirror blinker and courtesy lamp, ill have to call and see if they are addable
Old 06-21-2012, 05:55 PM
Rep:14
Well, unless I missed something on factorchryslerparts.com it looks like there isn't a different wiring harness unless you have the Longhorn accent lighting, so in theory if you get the modules and the flash they should work.
The dealers have to add the 3 digit codes to your vin via dealer connect. Once they do this wait about 3 hours and then flash your trucks TIPM. The mirrors should spring to life after that.
So this may be doable for about $180 if in fact the door harnesses have the wiring. If we could convince someone with stock trailer tow mirrow with signals to count the wires coming into their door module we could compare and confirm.
Old 06-21-2012, 07:47 PM
That would be nice. Pulled my passenger door panel off and the mirror harness I have now has 5 wires just with th heat and power and I see 2 more spots on the module that could have pins so I'm thinkin the tow mirrors have 7
Old 06-22-2012, 10:43 AM
Rep:14
How many wires are in the harness going from the door module to the truck?
Old 06-22-2012, 01:01 PM
I didn't check that, I think there was actually 3 plugs that go to the module including the mirror one, i'm leaving for work now but i'll check in the morning
