Old 05-11-2012, 09:00 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
I have 10" lift and 37s with 4.56s....I usually avg 13ish-15ish, all depending on how I drive. Granted this is all 50/50 city/hwy driving and hwy kills my mpg. I havent got below 13ish since I got the gears. Also everytime I get in the truck I kill TC and put it in 5th. Just took this on the way to work, probably one of my better tanks....
FYI buddy with 6' and 37" Toyos and 3.92s stays 9-10mpg
[CENTER][SIGPIC][/SIGPIC]
Old 05-11-2012, 07:10 PM
cyrus19 cyrus19 is offline
Vehicle: 2011 Ram 1500
cyrus19 is on a distinguished road
Candy if I had the money I'd go with a setup like yours but I don't. Lol. My stock truck right now is getting 14.9 so im guessing I'd go down to around 11ish.
My dealership is still strong in the Mopar lift being the only warranty safe lift. So I'm still undecided which way I'm going to go.
Thanks for the input fellas
Old 05-12-2012, 12:50 AM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
Wow, I baby my crew cab 4x4 with stock 17's and I get 11.5mpg. What's the secret? 2 more MPG would be prefered if I can get it. I'm hoping the mileage will go up after breakin period is over, but not crossing my fingers.
Old 05-12-2012, 11:41 AM
jdwills6925 jdwills6925 is offline
Vehicle: 2006 Dodge Ram Mega Cab
Color: silver
jdwills6925 is on a distinguished road
I have an 06 megacab with a leveling kit n 35s. I see about 9-11 depending on if im late for work or not!
Old 05-13-2012, 11:06 PM
duck2010 duck2010 is offline
Vehicle: 2010 ram 1500
duck2010 is on a distinguished road
i have a 2011 with a 4" and 35's on 22's and i get 13-15 on interstate going 70 and when towing 2 rzr's and 2 quads i get bout 8-9ish but the 22's are heavy!! id like to get some 18's and 35's i think it would be way better setup. i have 3.92 gears and just a aftermarket muffler
Old 05-14-2012, 10:34 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Something aint right there my friend. I live in a terribly hilly area in SoCal and my truck never dips below 14.5. I have full exhaust (long tubes/catback) and my MPG actually went down just a little because of my loss in low end power, but Ive never been anywhere near down there. Towing across the country i still averaged 10.5.
What gear ratio are you running?
2011 Big Horn 4x4 -SnowWhite-
Old 05-14-2012, 12:52 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
I've only put one tank of gas on my truck since I put my 4" lift with 35's on and I got ~17.5 L/100kms, or 13.4 MPG. I have 3.92's
Old 05-14-2012, 01:54 PM
sourbeer sourbeer is offline
Vehicle: 2012 1500 CC outdoorsman
Color: silver
sourbeer is on a distinguished road
Default fuel calculation
I think that it is difficult to know what fuel mileage you get when you run bigger tires on it, as the computer calculates mileage based on distance traveled and fuel consumed. Distance traveled is off by a certain percentage when you go to bigger tires and then the fuel calculator in the truck, and even when hand calculated unless you use the actual miles traveled (as per a GPS).
My last truck, a 2010 F350 diesel with 35" tires and tuner, was a pig and the fuel mileage calculator in the dash was not correct at all after I installed a tuner (fuel mapping, tables, etc.). And when hand calculating, the tire size was off and the odometer was off, so if I wanted to calculate the mileage, I needed to use a correction factor that I determined by using a GPS vs. my odometer.
so, correct me if I am wrong, when changing tires on the new Dodge, is the odometer somehow remaining accurate?
I am new to the dodge, just installed a leveling kit and am thinking of going bigger. I thought the 3.92 gearing would be good for 35" tires.
Old 05-14-2012, 03:35 PM
SS4Luck's Avatar
Rep:310
the tuner on your ford would not correct for tire size? Ive never heard of a tuner that wasnt able to do that.
Tuners for the dodges allow for change in tires size in the compuyter so odometer readings stay accurate
Old 05-14-2012, 11:25 PM
BradZ's Avatar
BradZ BradZ is offline
Vehicle: 2011 Dodge Ram QC
Rep:23
BradZ is on a distinguished road
i'm really wanting to do either a 4 or 6" lift on mine but damn some peoples gas mileage is looking rough.
