Old 05-16-2012, 05:01 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Mine rubs on the sway bar, driver side at full lock.
Old 05-16-2012, 09:18 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
I just want to be sure, you said you have the stock 275/60/s om stock wheels? I will go and check clearances now. thanks.
Old 05-18-2012, 06:37 PM
916Timmy's Avatar
Rep:1443
Yep, stock 20" with 275/60
Old 05-19-2012, 12:22 AM
Ramfd's Avatar
Rep:150
wow, ok your right i have slight tire rub on the driver side sway bar, but no rub on the passenger side. So i guess guys that are running wider tires, just live with the decreased turning radius due to not being able to turn to full lock?
or i guess get wheel with less back spacing?
Old 05-19-2012, 01:24 AM
916Timmy's Avatar
Rep:1443
Yep just the driver side, not bad though. Just be easy backing out
Old 05-31-2012, 03:47 AM
spymac's Avatar
spymac spymac is offline
Vehicle: 2011 Ram 1500
Color: Deep Water Blue Pearl
Rep:41
spymac is on a distinguished road
Any updates? Which tire did you end up going with?
I'm currently shopping tires and have the same concerns as you.
For the 285/50 size, check my thread for Zevox's pics. I like the look a lot but only if the truck is lowered.
http://www.ramforumz.com/showthread....t=275%2F55
Old 05-31-2012, 11:41 PM
Ramfd's Avatar
Rep:150
still havnt bought any. just cant seem to make up my mind.
Old 09-13-2012, 05:53 AM
cyberpine cyberpine is offline
Vehicle: 2010 Dodge Ram Quad Cab Hemi
Rep:53
cyberpine will become famous soon enough
Did you ever try out the 295/50/20s on stock chrome clads? I'm thinking about it, but looking to know before I try. Damn shame our chrome clads did not come in 0+ offset, would have made for many more options, especially since these trucks looks so good with wider tires and a more negative offset. Emails welcomed on the subject as my stock 275/60 are almost down to nothing.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
