Old 05-12-2012, 03:26 PM
hunter.shawn's Avatar
hunter.shawn hunter.shawn is offline
Vehicle: 2000 Dodge Ram SLT
Trim Level: SLT Laramie off road
Color: Pearl garnet
hunter.shawn is on a distinguished road
Default Axle Seal Leak HELP!!
Allright so my driver side axle is leaking a good bit. I plan on fixing it myself.. no special tools. Heres the kicker. my truck has the *off road package.. I know that it has slightly different axles.. would this call for a different type of seal/procedure? Any help is appreciated!
women< my dodge
Old 05-12-2012, 05:15 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
Whether you have 4x4 or 2x4 that has a front or rear axle seal that is leaking, when you pull that axle out, pull the seal out and take it with you to the auto parts to match. Saves a trip back if it doesn't fit.
Old 05-12-2012, 05:46 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
You said driver's side...front or rear?
Old 05-12-2012, 11:28 PM
Color: Pearl garnet
Doh! front haha! And I figured that would be a good plan. This off road package tends to make things slightly more complicated.
women< my dodge
Old 05-13-2012, 01:30 PM
Vehicle: 95
Rep:1776
Yuck.
You're going to have to get in there to change the seal:
1 - INDICATOR LAMP SWITCH
2 - DISCONNECT HOUSING
3 - VACUUM SHIFT MOTOR
4 - AXLE SHAFT
5 - SEAL
6 - SHIFT COLLAR
7 - SHIFT FORK
8 - BEARING
9 - INTERMEDIATE AXLE SHAFT
My turn...Doh, still learning up and down...or was that right and left. Anyway, I'll just leave this right here.
Old 05-13-2012, 08:16 PM
Color: Pearl garnet
Allright^ is moving the shift collar/shift fork needed? I am going to follow a procedure similar to this one if it makes any sense... and where would this indicator lamp switch be located?
women< my dodge
Old 05-13-2012, 08:37 PM
Color: Pearl garnet
Disregard my last haha, that diagram did not show.. Allright I went and looked.. the whole assembly should disconnect when I pop those bolts right? (parts 1/2/3) and everything else should slide out simply... I know I will be replacing both seals.. This will be a beeech.
women< my dodge
Old 05-13-2012, 09:55 PM
Vehicle: 95
Rep:1776
Yeah if it's not broken it should come out as one unit.
