Place your Ad Here!
Old 05-12-2012, 04:51 PM
thunder92 thunder92 is offline
Vehicle: 2000 ram sport 360 v8
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
thunder92 is on a distinguished road
Default shift solenoid-A code. Which one to buy??
My truck is finally throwing a code after fun revving problem from 2 to 3rd gear. Took out relay and swapped with another and bam the code came on. Autozone says the solenoid is $120ish and napa says $39 bucks. Anyone have a part # for this? Autozone can't even get it so a napa part #.
Thanks
2000 ram 4x4 5.9 auto
Old 05-12-2012, 07:38 PM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500, 2001 Ram 1500
Color: 2500 White, 1500 Black
Rep:97
SnoopyIsMyHero will become famous soon enough
Thanks
Which solenoid? If the NAPA one is $30, it's probably for the older RH transmission, if you have the RE tranmission it will run you about $70. Check out these (courtesy of ramvan2500)
http://www.makcotransmissionparts.com/12415B.html This is the gov sensor
http://www.makcotransmissionparts.com/12432A.html This is the gov solenoid
http://www.makcotransmissionparts.com/12420B.html This is the TCC/OD Solenoid/ Gov Sensor+Solenoid Harness
2001 2500 5.9 4x4. Stock except for exhaust, step rails but I don't care, I love my beast
2001 1500 5.2 4x4. Stock except for exhaust, my new project.
