Old 05-13-2012, 04:50 PM
DetFrankBullitt DetFrankBullitt is offline
Vehicle: 2012 Dodge Ram
Trim Level: SPORT W/LEATHER
DetFrankBullitt is on a distinguished road
Default Bilstein 5100's ???
The Bilstein 5100's look great but what increments can they be adjusted to? My truck is 1 & 3/4 in lower in the front if you measure from behind the front tire to the ground and in front of rear tire to ground! Thats a bit much but I do like some rake! A 3/4 in lift would be perfect for me so still have the rake but would sag to level with dirt bikes and gear loaded! Is that possible and do you do fronts only or both front & rear shocks? Part # front BSN-24-187367 at Summitt! Rear part # ??? Thanks for any and all help! BLAKE!
Old 05-14-2012, 01:30 PM
sourbeer sourbeer is offline
Vehicle: 2012 1500 CC outdoorsman
Color: silver
sourbeer is on a distinguished road
Default 4 positions
I just had these installed last week on mine. I had mine installed at the highest setting 2.8" higher than factory and it is perfect for me. Mine is a crew cab outdoorsman package truck.
I'm considering going a little higher yet, need to figure out what lift I might want to comfortably fit 35" tires on it.
i don't recall the part number, but I bought mine from Summit as well and they were the only place that had them in stock. You need the Bilstein 5100 series shocks for the year/model Dodge that you have - they do make them for the rear as well but they are replacement shocks only and do nothing with the height. Front is all that I installed and it looks and rides great. i did get the front end aligned after installation.
Old 05-14-2012, 05:59 PM
hammer1 hammer1 is offline
Vehicle: 2012 Ram
hammer1 is on a distinguished road
I went with the 2.1 inch adjustment and it still has alittle rake!! I think you will be very happy with that setting.
Old 05-14-2012, 07:27 PM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
Doesn't it go by .7 increments? could be wrong but i thought it was 0.7, 1.4, 2.1 and 2.8? not positive
Old 05-15-2012, 11:27 AM
Hemi1536's Avatar
Hemi1536 Hemi1536 is offline
Vehicle: 2011 Ram 1500 ST
Trim Level: ST Quad Cab
Rep:13
Hemi1536 is on a distinguished road
Yep sure does. Just put a set on 2 weeks ago
Never Butt Heads With A Ram
