Old 05-15-2012, 08:20 AM
Hapas's Avatar
Hapas Hapas is offline
Vehicle: 2001/2010 Dodge Ram 4x4
Trim Level: 01SLT Lariat/10 Lar
Color: 01 Pat Blu/10 Min Grey 2 tone
Hapas is on a distinguished road
Default Clicking noise coming from front end.
I have a 2001 Off Road pkg, with 5.2L, 315/70/17's and a 2" leveling kit. I have just over 117k miles, and getting a clicking noise from the front end. I have talked with some friends, and they are saying CV joints. Would like to confirm. Any help would be appreciated.
Old 05-18-2012, 05:42 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
Need more information.....
Is it happening while driving at highway speed, in town, off road, while turning, in 4 wheel or 2 wheel? Possible engine noise? I know some small 4X4 trucks might have CV Joints but not sure about Dodge full size. Thought they are U joints but not sure. I do know when U Joints start going bad the little needle bearings start making a clicking sound. Could gease them if they have a gease fitting.
Old 05-20-2012, 07:38 PM
Hapas's Avatar
Default Clicking
Thanks for the response!! I first noticed it while in 4WD while turning. I may be paranoid now thinking I hear it while driving in town, though that could be my tool box. LOL. I am pretty sure it is not an engine noise, and it could very well be the U joints, I may have misquoted by saying CV.
Old 05-24-2012, 08:14 PM
SportHD SportHD is offline
Vehicle: 1998 dodge ram
Trim Level: sport
Rep:43
SportHD is on a distinguished road
When my front u-joint went bad it started off by only making the sound in 4wd. But as the joint got worse, you could start to hear it just driving around in 2wd. Especially at slow speeds. Grab ahold of the front axle shafts and wiggle them. If there is any play in the joint its done..
Old 05-25-2012, 12:19 PM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500
Rep:86
SnoopyIsMyHero will become famous soon enough
Same here. And they are ujoints, not CVs. You can replace just the joints in the shafts which is good, because the axle shaft assembly is not cheap.
2001 2500 5.9 4x4. Stock except for exhaust
Old 11-03-2014, 04:58 PM
bpico1 bpico1 is offline
Vehicle: 2003 Dodge Ram
bpico1 is on a distinguished road
Question Front end
Hello gents I have a simple 2003 1500 with a 4.7 it has almost 200,000 miles on it and when I cut the wheel hard to either side I hear almost like a click from the front kind of like when you dislocate a joint in your body and it goes back in I think it is my tie rod ends but I am not sure it is definitely coming from the steering system of the truck. If anyone has any idea as to what it is I would appreciate it
-Ben
Old 11-04-2014, 10:42 AM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
bpico1- the tie rod ends do go bad on our trucks. Also check that the upper control arm bolts haven't loosened up. I had my alignment done and they left one loose and it would clunk whenever I moved the truck.
Old 11-04-2014, 09:28 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
X2 with the others on the front "axle-joints", Hapas. I recommend a set of Spicer u-joints. If you get the local A-Zone parts, you'll be replacing them again in a few years. But be prepared, once you get into the front-end, you tend to find alot of other things that need work as long as you are in there. Check the ball-joints and tie-rod-ends. Hub bearing feel good? Just saying that this is one of those little-jobs that can turn into big ones. And then there is the OTHER side of the truck........
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 12-06-2014, 07:36 AM
thanks as soon as I get a chance I will look into it -Ben
