Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Advanced Automotive Concepts - AACstyle - Dodge Ram Accessories!
Advanced Automotive Concepts - AACstyle - Dodge Ram Accessories! Advanced Lighting Solutions for High-End Vehicles! - Dodge Ram Accessories - Dodge Ram Parts!
Old 05-15-2012, 03:55 PM
Justin@AACstyle.com's Avatar
Justin@AACstyle.com Justin@AACstyle.com is offline
Vehicle: 2500 MEGA-CAB
Color: errr...custom
Rep:114
Justin@AACstyle.com will become famous soon enoughJustin@AACstyle.com will become famous soon enough
Thumbs up NEW Product: Bighten up your Garage with ORACLE LED Shop Lights!
New Product! Check out these awesome new LED Shop Lights from Oracle Lighting.
LED lamps have HUGE advantages over conventional Halogen lights besides looking better and consuming less power they are also more durable, brighter, and last 8x longer.
Check them out here:
http://www.automotivelightstore.com/shoplights.aspx
SAVE! Form Members enter code: "SHOPLITE" to get 10% OFF your ORACLE LED Shop Light Purchase (coupon only applies to items in this category).
More Info:
LED Shop lights have many advantages over traditional halogen work lights. The LED versions are 10x as efficient as halogen, this means a 30W LED light would be equivalent to a 300W Halogen, that is some serious energy savings! LED work lights also put out no heat which makes for a much more comfortable working environment. Halogen work lamps are known for being fragile, if you were to drop a halogen lamp it would no longer work while LED work lights are completely shock-proof. Halogen lamps will burst if splashed with water while heated, these LED units are waterproof and can even be used in the rain.
More LED Shop Light Advantages:
•High efficiency eco-friendly Bridgelux LEDs only consume 1/10th the power of a traditional halogen lamp.
•LED lamps do not put out any heat while halogen get so hot that they can actually burn and cause injury.
•Bridgelux LEDs are rated at 50,000 hours of continuous use, that is 8x longer than a standard halogen bulb.
•ORACLE Shop Lights feature premium Bridgelux LEDs which are powerful, high quality chips MADE IN THE USA!
•These Solid-State lights are shockproof and will not go out if jarred or vibrated like a halogen bulb would.
•ORACLE LED Shop Light housings are rated for outdoor use and can be used in wet, rainy, or snowy conditions.
-Justin
For ALL of your RAM Lighting Needs!
1(800)407-5776
www.AACstyle.com
Old 05-15-2012, 06:22 PM
1989doubleD's Avatar
1989doubleD 1989doubleD is offline
Vehicle: 1989 dodge ram dually
Trim Level: w 350
Color: clasic gray and black
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
1989doubleD is on a distinguished road
those look sweet
Old 05-17-2012, 01:41 PM
Rep:114
Originally Posted by 1989doubleD View Post
those look sweet
Thanks
-Justin
1(800)407-5776
www.AACstyle.com
