Old 05-16-2012, 11:12 AM
staypuff staypuff is offline
Vehicle: 2012
Trim Level: Bighorn
staypuff is on a distinguished road
Default Strange cai issue
I have the K&N 63 series CAI and when I go WOT it feels like the truck is bogging some and I get a stinky smell. Only other MOD is removed the stock y-pipe and replaced with true dual into DI/DO magnaflow.
I reinstalled the factory intake system and the issue goes away.
I was thinking the ECU is registering more air movement than exspected and torque manamgement is kicking in. If i only go say 3/4 throttle the truck goes like a bat out of hell.
Anyone else have this issue?
Old 05-16-2012, 11:41 AM
CanDan's Avatar
CanDan CanDan is offline
Vehicle: 2012 1500
Color: 1500
Rep:23
CanDan is on a distinguished road
Possible things to look at:
1: Reset your ECU - Disconnect your battery for 10minutes
2. Damp filter - Did you clean your filter or oil it too much before install?
3. Dirty or damaged MAF
4. MAF installed backwards (Not sure about the RAM but this does matter on some cars)
I would check these things first. Changing a intake should not be causing this.
Can you explain the smell? Any smoke, what colour?
*note, I am still waiting for delivery on my RAM and thus have to experience on the truck. I am just looking at possible simple causes that are pretty generic to most engines.
Old 05-16-2012, 11:43 AM
CanDan's Avatar
Vehicle: 2012 1500
Color: 1500
Rep:23
*Edit: Check your vacuum hoses. This reminds me of a vacuum leak problem now that I think of it.
Old 05-16-2012, 01:28 PM
Vehicle: 2012
Trim Level: Bighorn
it's kind of a sulfer smell.
i don't have a MAF sensor or none that I can see. All I have is a little IAT sensor in the intake tube.
The filter is brand new out the box. it wasn't dripping with oil or anything when I installed it.
I haven't tried reseting the ECU yet.
pcv hose setup looks fine. Maybe i'll inspect it for cracks
Old 05-16-2012, 01:41 PM
HemiSwagg's Avatar
HemiSwagg HemiSwagg is offline
Vehicle: 2012 Ram 1500 Express RC
Color: Mineral Gray Metallic
HemiSwagg is on a distinguished road
Strange...I have a burnt sulfery type smell as well on mine but only at WOT. All I have is a K&N panel filter and a magna flow y pipe to a cherry bomb mufler.
Staypuff - Question...at WOT from 1st to 2nd is there any type of hessitation in the shifting and does exhaust make a strange sort of pop sound? Mine does and thats when I get the smell. Maybe the ECU is not adjusting to the increased air flow some how and is not burning the gas properly...
K&N Panel Filter, Magnaflow Ypipe, Cherry Bomb Muffler, In-cabin air filter mod, 3.92 with LSD, Fastman Standard MOD TB.
Old 05-16-2012, 05:24 PM
Vehicle: 2012
Trim Level: Bighorn
1st and 2nd seem to be fine from a stop. It's more noticable when I'm already moving and kick it in to pass someone. I tried swaping the stock air box setup back in and it fixes it. I think it's tune related. I'm gonna put the stock setup back in till they come out with a tuner. after a tuner comes out i'm going with LT's, ORX pipe and a cam as well
Old 05-17-2012, 02:43 PM
HemiSwagg's Avatar
staypuff - yeap mine does it when passing as well. Quite annoying.
Ahh yess...longtubes with x pipe to true duals would be sick. Throw in a cam and a tune (whenever that happens) with the intake and possibly a fastman TB...you'd be in good shape. I called Hennesey Performance and they said American Racing Headers makes adapters for the 2011-2012 5.7's. Regardless, without a tune it would be a waste.
So, your going back to stock? As in putting the stock exhaust back on as well as intake? It would be interesting to see if you feel a difference. Have you gone to the track? What did you do before and after the intake and exhaust mods?
