Old 05-16-2012, 12:46 PM
John French John French is offline
Vehicle: 2002 Dodge Ram 1500
Color: Blue
John French is on a distinguished road
Default '02 4.7L Shakey Idle Then Stalls
New here and need some help.
2002 Ram 1500 4.7L w/128,000 miles
Background: Saturday I picked my truck up from having it painted, and when i left the shop the truck was running really rough. check engine light was on. I took it into autozone and had the codes pulled (cant recall the actual code) basically it was a misfire on cylinders 5&6. i knew i was way past due for new plugs, so i installed the NGK V-power plugs gapped to .044, also cleaned the TB really well. Drove it and it runs great, no longer does the idle feel weird or feel like its running on 1/2 the motor as it did when i picked it up from the shop. Drove up to the gas station to get some gas. i did not have the a/c on, and the tach fluttered about 200 rpm, didnt recover from it and it died. thought it was odd, but i had had the battery disconnected for quite a while so i figured it was still reprogramming it and thought nothing of it. so i went ahead and got gas, and dumped in a bottle of injector cleaner.
The next day i was driving it to work, still running fine. sitting at a stop light the truck was idleing about 600 rpm, it started to flutter about 200 rpm and cought itself and idled uptop about 900 rpm and leveled back out. pulled up to the next stop light and it started doing the same thing, this time though it died, like it didnt catch itself. it did this to me another 4 times on the way to work. on the way home i turned the a/c on and driving it and at stop lights it did the 200 rpm flutter but never died. This morning on my way into work again and not running the a/c and it died a few times. i turned the a/c on and it would flutter but never die at the stop lights.
Can anyone give me any advice with what to look at or what to do about this, its really driving me nuts.
The truck used to do this a occasionally before i changed the plugs but would never die.
Old 05-16-2012, 10:41 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
I recommend changing the spark plugs back to Champions OEM part # RC12MCC4 and gap them to (0.040 in.). 4.7 don't like to many plugs on the market except the oem style copper.
Also start looking into the crankshaft position sensor which controls many of the symptoms that your having. Some major symtoms of this sensor on 4.7 are cuts off as soon started,Backfires,Irregular RPM Function and false sensor reading causing incorrect timing and signal to the pcm.
Test your idle control valve to make sure it's opening and closing correctly and your TPS these sensor are main control of your throttle signals and idle signal to your pcm with out all these sensor working at the correct specs your pcm with start giving you your problems your having.
Old 06-23-2015, 05:48 PM
dgm dgm is offline
dgm is on a distinguished road
Hello to the Dodge Ram family. This is my first post on the forum. Basically I have a 2002 Ram 1500 4.7 that I purchased brand new in Dec 2001. About 6 months ago I started getting a rough idle and sometimes it would stall when sitting at a signal. Long story, short: I have changed the TPS, IAC, cleaned the Throttle body, disconnected battery etc etc. I am not getting an engine light or trouble code which compounds the problem. I would appreciate any help or advice on repairing this problem. I've got 165,000 miles on it and all Original.
DGM
