Place your Ad Here!
Old 04-10-2013, 10:50 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Originally Posted by Ramfd View Post
http://youtu.be/sd1-CWsRQjc
here is the link for the sound clips.
Dude! Your truck sounds CRAZY good
sales@revelperformance.com
Old 04-10-2013, 02:08 PM
Rich859's Avatar
Rich859 Rich859 is offline
Rep:351
Rich859 is just really niceRich859 is just really niceRich859 is just really niceRich859 is just really nice
That sounds amazing!
Revel Performance Sponsored Truck
Too many mods to list. Full list can be found on my profile.
Old 04-11-2013, 01:27 PM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1503
KA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant future
from green to red
red LED bed lighting
white LED cargo lights
Everything is looking awesome!! I'm a chrome lover, but what you're doing with the carbon is simply stunning.
A few questions.. would you mind laying out the process with which you changed your map light bulb?? Also, what product did you use for your bed lighting? Since it illuminates red and white.. is it a tailgate bar? And where did you run the wiring.. is it wired to auto illuminate with your bed lights? Or did you install a switch somewheres? Thanks!
Old 04-11-2013, 06:46 PM
Revel Performance
Rep:1804
Very Nice.
Love the lighting.....
Old 04-11-2013, 09:15 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
thanks guys I am really loving the intake and exhaust. I still want to add headers and a tuner in the future.
for the lighting, I really cant help too much on the over head light, only because i used a red LED that i had lying around, and i dont even know for sure how i acquired it, so i couldnt tell you the specs on it. But, all i did was unplug the original light and removed it form the console, then the LED just wedged down into the existing hole and i hard wired the led into the stock wire harness, the LEDs are polar sensitive so if they dont work they might be wired back wards.
the bed light as you guess are tailgate light bars, I just made sure i got ones with reverse lighting. I have relays mounted under the dash and ran the power wire under the truck and up to the front of the bed under the bed cover. The red lights are wired to a switch in the dash that also powers the RAM logo. I plan on adding more red accent lights in the future. the white lights are wired to a switch that is mounted in the bed near the tailgate, that one i taped into the trailer harness for a hot constant power so i could have bed lights with out have the key in the switch.
Did i make that as clear as mud? lol
Old 04-11-2013, 09:17 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Love the lighting
Thanks
Jeremiah
Discount Auto Performance
Old 04-12-2013, 11:42 PM
KA1OTE's Avatar
Ram Ham
Rep:1503
Perfectly, thanks for the detailed info! Gives me more fodder to contemplate over on the bed lighting topic.
Old 06-10-2013, 03:21 AM
Ramfd's Avatar
Rep:150
bought a crankcase vent filter and plasti diped the chrome
also plasti dipped the yellow caps, brake reservoir, washer fuild cap and coolant over flow cap
Old 06-10-2013, 03:27 AM
Ramfd's Avatar
Rep:150
ok here it is the DODGE logo from the top of the center dash stack. got it cut out and fitted, just need to get more red LEDs. and get it wired up, for got to get a pic on the truck but i will have one soon.
the back view, this one took a little more work to get it to fit in the tight space, then I used gorilla glue to afix it.
side profile of the plexiglass
you can see the raised letters here
Old 06-10-2013, 06:32 PM
Revel Performance
Rep:1804
For always setting the trend
