Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 05-17-2012, 03:03 PM
nascar88's Avatar
nascar88 nascar88 is offline
Vehicle: 1985 D150 Prospector
Trim Level: Royal SE
Color: Tan
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
nascar88 is on a distinguished road
Default 1985 D150 reverse light problem
I just bought a 1985 D150 prospector the other day from the original owner who was 84. Not until i got home did i realise that the reverse lights did not come on in reverse but they did come on when put in park. i thought the neutral safety switch was bad or the shifter linkage what out of alignment. But both of those checked out fine. Does anybody have any ideas on what it might be? The truck has a 318 with a automatic and 4x4 if that helps at all. Thanks for the help
Old 05-18-2012, 02:34 AM
moparornocar72's Avatar
Rep:630
I would check the light bulbs. if those are good check the housings and make sure u have power then work ur way back
14.268 @ 95 MPH Full Trim
Old 05-18-2012, 05:37 PM
nascar88's Avatar
Color: Tan
I went back threw and checked everything and it still wasnt working. But about a hour later i went back out to mess with it and somehow it had started working. Im glad its working now but still wonder what was causing the prblem
