Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 04-18-2011, 12:21 PM
TxAg2007 TxAg2007 is offline
Vehicle: 2005 Dodge Ram 3.7L
TxAg2007 is on a distinguished road
Default '05 misfire and rough idle at start
For the past month I have had an issue that has been perplexing me and my mechanic. I'll start up the truck, and after about 200 ft I come to a stop. The truck will dip below 500 rpm, and shake violently. It does it for 30 seconds tops. After that the truck will continue on as normal. The CEL came on, and was spitting the obligatory P0300 code. I took it down to my mechanic who did some work on it. I did some work on it too. This is what has been done so far:
All O2 sensors replaced
IAC valve cleaned
TB cleaned
Seafoam treatment
Even with all of this work done, it continues to do the same thing. I feel as though it may be idling a little heavy, but nothing like when I start it in the morning. I've heard that this problem could be a range of issues, from asymmetrical valve, to ignition coil. I thought I'd get y'alls take. Thanks in advance.
Old 04-18-2011, 12:26 PM
Rep:1909
You need to find out which cylinders are misfiring. Still sounds like heavy carbon buildup on the valves to me.
Old 04-18-2011, 12:34 PM
Wouldn't something like a Seafoam treatment rid most carbon build-up? I've run two for good measure, and there has been no change. The mechanic ran a full diagnostic test, and he cant seem to pinpoint which cylinder is misfiring.
Old 04-18-2011, 12:40 PM
Rep:1909
A DRB III scan tool will tell you which cylinder is misfiring. If the carbon buildup is thick enough, SeaFoam won't fix it. The heads will have to come off and the carbon removed with a wire wheel on a grinder or the valves will need replacing.
Old 04-18-2011, 12:46 PM
Thanks RamTech. Is there a possibility of it being a vacuum leak? I've heard that these are common issues also.
Old 04-18-2011, 12:51 PM
Rep:1909
Pretty unlikely at this point. I would think your mechanic would already have checked for this.
Old 04-18-2011, 12:54 PM
Ok. I'm starting to think my current mechanic is a bit inept. Thanks again.
Old 04-18-2011, 12:55 PM
Rep:1909
If you want to check for a leak yourself, get a can or carb cleaner and spray any suspect areas while the engine is running. If there's a leak, you'll hear a change in engine rpm.
Old 06-30-2011, 02:12 PM
So I brought the truck to multiple mechanics since my problem began. I had one do as you had said. Apparently it wasn't the problem. So this is the list of things that have been replaced/fixed/done:
Camshaft sensor replaced
crankshaft sensor replaced
All Spark plugs replaced
Decarb - twice
IAC valve checked
Fuel treatment
My last trip was made to the dealer service dept, who claimed it was faulty spark plugs. It wasn't. So it's been 5 months now. Not even a Dodge mechanic could diagnose and fix it. What the hell could it be?
I read this somewhere:
Vehicle Issue Engine Runs Rough. MIL On. Will have one or more of Fault Codes
P0300 - P0308.;1999 - 2005 3.7, 4.7, 5.7 engines. Possible fault codes P0300,
P0301, P0302, P0303, P0304, P0305, P0306, P0307 and P0308. Cylinder leakage
test indicates air leakage past valve. There is no visible problem with valve
when head is removed.
Recommendation With the cylinder head removed, use a known good valve and coat
the valve facing / valve seat contact area with valve lapping compound. By
hand, firmly pull the valve against the seat and rotate valve a few times.
Remove the valve and check for a Symmetrical contact pattern on valve seat. If
the pattern is not symmetrical replace cylinder head. If pattern is good,
replace suspect valve.
I have just about given up on this truck.
Old 07-05-2011, 08:05 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Is it just the P0300 or are you getting specific cylinder misfire codes too?
How is the wiring harness? No frays or cut wires?
Stock Cam?
If the wiring harness is okay then i would have the valve covers pulled to check the push rods to make sure they are seated correctly.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
engine misfire rusty226 5.7L V8 Specific Topics 1 04-14-2011 12:27 AM
New 2010 Hemi Rough Idle jimw 5.7L (345 cu in) HEMI V8 Specific Topics 3 06-20-2010 02:07 PM
Misfire Cylinder 1,2,3,4 HELP! DetroitDodge1989 4.7L PowerTech V8 Specific Topics 7 02-28-2010 02:11 PM
2001 Rough Idle lurch 5.9L V8 Specific Topics 1 01-29-2010 04:04 AM
